Question about Kenwood VR-715 Receiver
Kenwood VR-715 I have a old kenwwod, but running very well, Now I bought NetGear EVA8000, and when I try to connect it in VIDEO 2 INPUT, using a digital connection. The light DIGITAL in Kenwood turns on, but there is no sound I try coax and optical cable and none works. Only NO DIGITAL connections works
cancerags
  • 36 Answers
SOURCE: Kenwood VR-715 reset?
Hello llarosa,
Yes, there is. Unplug the power cord from the wall outlet, then
plug it back in while holding down the POWER ON/STANDBY key.
That will clear the contents of the memory, reset the microcomputer and take the unit back to factory settings. Hope this helps. Let me know.
cancerags
Posted on Dec 31, 2007
SOURCE: No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Posted on Apr 12, 2009
shahabdun
  • 249 Answers
SOURCE: optical input not working
Was it plugged in the right places?
Posted on Jul 06, 2009
smarthome2
  • 1114 Answers
SOURCE: kenwood vr-5900 no sound
Check you settings on the receiver. get into the menu of the unit and check the "Audio" settings. if you can choose by specific input, select "Digital" otherwise, select "Auto" that should correct the problem. If you still have a problem, post a comment and I can help you troubleshoot some more.
Posted on Jul 26, 2009
dancandoit
  • 436 Answers
SOURCE: how do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Posted on Dec 27, 2009
I am connecting an amplifier to my VR-407 to accomodate more speakers I have installed throughout my home. Where do I connect the amplifier?
Connect the amplifier input to the VR-407 using the receiver's REC OUT jacks for the MD/TAPE input on the back panel. This is a fixed line-level output for recording, and will work fine for driving the additional amp.
Jan 17, 2011 | Kenwood VR-407 Receiver
How do I connect my Kenwood VR-715 surround sound system, Dish Network receiver, and HD LCD TV together so the surround sound works? Can't figure out what goes in the input, the order of the connections or...
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
Jan 08, 2011 | Kenwood VR-715 Receiver
Kenwwod VR-615 - display disappears
Its becuase it is dirty inside, Unplug it. Take the case off of it. Get sum compressed air from a computer store or Walmart. Like 10 dollars. And just blow the whole thing out with that canned air. do it ever 3 months.. It should fix the problem for life!(:
Jan 30, 2010 | Kenwood VR615 Receiver
How to hook up a kenwood audio-video surround receiver vr-405 to a 46" Bravia tv?
hello all you need is a good pair of RCA cables.
Use the audio output on the TV
run it to the VIDEO 1 input on the receiver
as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
or
use the receiver as a video switcher and connect your components directly to it.
remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
Hope that helps
Jan 10, 2010 | Kenwood VR-405 Receiver
I have a ps3 and a samsung flatscreen im using an hdmi cable is there anyway to run the sound through my kenwood vr 305 since it doesnt have a hdmi input
Connect cables from your flatscreen TV (or monitor?) to the receiver's audio input jacks. These could be two RCA, white and red, or Digital (one single RCA cable), or optical, if both the flatscreen and the receiver have such connector. Make sure you select the correct audio input on the receiver to amplfy the sound from the game/movie/etc.
If successful, try muting the TV's audio, to prevent the sound from creating a hollow (echo) effect.
Dec 02, 2009 | Kenwood VR-305
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
Hello llarosa,
cancerags
Dec 31, 2007 | Kenwood KRF-V5060D Receiver
IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
Nov 22, 2007 | Kenwood VR-309
Kenwood VR-715 Receiver Logo
87 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
