Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Can't clear the "HF" code
My washer keeps stopping after 6 -10 min and flashes "HF" Ihave checked the water valve are open all the way I replaced the hoese and have taken the front pannel of and unscrewed the white filter pump thing which actually was not that dirty unpluged and replugged the machine in several time to clear the HF which it does but when I run the machine again to test it it come right back up again after 6 - 10 min anyone have anyother Ideas of what to try? Thanks
  • wrightgirls2 Sep 15, 2008
    omg Thank you so much you just saved me over $100.00 for just a sevice call! it was as easy as 123 I am already on my second load of laundry! your the best thanks again Jenn
  • jad1406 Nov 25, 2008
    Washer stops after 10 minutes or so - H and F flash alternately. If I press Cancel and then start it will run again for 10 minutes and again the same. If I cancel after this frustration I cannot open the door. I can use the drain or rinse cycles but the wash is a problem. This just started recently and I dont know why. Can you help?
    Novelist:
    Champion:
  • 261 Answers
Does your machine have a flow meter? Several items can cause this to happen.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1381535&PPStack=1
Follow this link to see what the flowmeter looks like.
Pop the top by removing the three screws on back top and push back and lift the panel. Behind the white box or dispenser on the left hand side you will see a black tube going to your fill valves, if there is one as pict at the link, shut off the water, undo the clips and noting flow direction fasten the leads of a ohm meter on to the leads. Watching the display blow into the flow meter, the ohms should go from 0 to above 14 if not replace. Also check the serial connect and trace to the ccu and unplug, plug in the connect.
Posted on Sep 15, 2008
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It has an HF error code. What does this mean?
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.(make sure the pressure switch hose is not filled with water as well. If so, replace the pressure switch asap).
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
I have the whirlpool duet and it stops mid-cycles and flashed FH on the screen. why?
This code typically indicates a fill problem. Much of the diagnosis of the problem depends on whether there is water getting into the machine. If there is no water getting to the machine then check the water inlet valve. Unplug the machine, turn off the water, and remove the suppy hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter and test continuity. A lack of continuity will mean a bad solenoid and the valve assy will need replaced.
If there is water going into the machine, then check for a faulty water level switch. Make sure the plastic tube attached between the switch and the bottom of the washer's outer tub is clear of any obstruction and is not damaged in any way. This code can also be generated by a faulty flowmeter. These are some things to consider.
If no water is detected filling the washer within 30 seconds, then the valve will be shut off and the code will be displayed OR if the water has turned on and after 8 minutes the flowmeter has detected 10.5 gallons of water passing through it, but has not detected a pressure switch trip, then the code will be displayed. These are the parameters that will cause generation of the FH code. Rather convoluted and I hope that you are able to follow my ramblings. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FLASHING HF CODE WILL NOT WASH OR UNLOCK
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
* Verify there is not a siphon problem
* Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
* Check all hoses for possible leaks
* Verify pressure switch operation
* Verify flow meter operation
* Verify CCU operation
Sep 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code HF
Or
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite
hi,
Or
hope this helps.....
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
Or
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Nov 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
252 people viewed this question
Sal De
fordexpert
Robert Rankin
