Question about Kenmore 53642 / 53644 Side by Side Refrigerator
How to remove ice/water panel on the outside of the freezer door
How do you remove the ice/water panel on the outside of the freezer door?
I don't want to just pry it off but, can't find screws to remove first.
Kenmore Side by Side #50522100
  • Anonymous Mar 25, 2014
    Removal of interior panels in ref area and freezer area.
Your model number appears to be the same as mine. If you gently pull off the panel marked with the ice/water by placing your fingernails just behind it and pull toward you the plastic panel should come right off. Behind that are the four screws holding the circuit board support to the fridge frame. All I did was pull the four screws, gently removed the wiring harnesses, tilt the plastic holder toward me and remove the two circuit board retainer screws to replace the board. Reversed the process of putting it all together and it worked like a champ.
I hope this helps.
Posted on Sep 17, 2008
Water leaking from top of fridge
If the case is cracked or there is a leaking door seal this will allow moist air from outside the unit to come in and release its moisture. Cracks are easy to see. You can also inspect the seals fairly easily.
IF YOU TRY ANY OF THIS PLEASE UNPLUG YOUR UNIT AND TURN THE WATER SUPPLY OFF FIRST. thank you.
Freezers/fridges remove moisture from the air inside them while they work. At least in my unit the fridge and freezer compartments are connected by a couple little trap doors. One near the top works automatically. I assume it regulates the temp of the fridge part by using freezer air. The other is vented into the meat drawer at the bottom.
Moisture flows to the coldest part of the inside, much like humid air settles droplets on the outside of a cold glass in the summer. The coldest part is the coil assembly which would be behind a panel at the back of most freezers. Below this assembly and hopefully not covered by a panel is a drain hole. It needs to be clear for things to work properly. See if you can find it in the back bottom of the freezer.
If there is ice plugging it you need to clear it. Don't pick at it because the inside of a freezer doesn't like scratches and scrapes. Those create opportunities for rust if the unit lasts long enough. Put a few towels in the bottom of the freezer to catch overflow. Then pour the hottest tap water you can get slowly over the ice. Once it is clear the drain lets the water go into a pan underneath the unit and eventually evaporates. You will hear it when it clears.
Under normal operations this drain collects the water that freezes all over the cooling coils in the very back of the freezer. It is normally very little water. If it is blocked by ice this can point to a slightly bigger problem. You may want to see if you can remove the back panel of the freezer and check the coils for ice. This can a)take a while and b)have you removing a lot of assemblies just to get to one panel screw. So be prepared and don't start it when you have a freezer full of food. If you attempt it and find white fluffy looking ice all over your coils you will need to look below this stuff for an assembly that houses a heater. Mine looked like a long thin tube bulb, much like a halogen lamp. It's called the heater element and replacing it may just fix your problem. I got mine for about $50.
You might also want to make sure your fan and radiator assembly are clean. Inspect the air venting grill on the back. If that is gunked up or you can see that the radiator inside is gunked up, you should carefully remove the panel and vacuum as much as you can. This was a major problem for me because at one time because of indoor pets. If checked regularly it doesn't become an issue.
Anyhow, this is a lot of info, but I had to learn all this the hard way. Hopefully it will save you and others a headache.
Dec 06, 2011 | Kenmore Top Freezer Refrigerator
Unit does not get cold
I have nursed a crappy side by side along for ten years. Here is what I have come up with to check:
Nov 25, 2011 | Kenmore Top Freezer Refrigerator
I have water off the freezer door outside the refrigerator
Here are some things to try. I have nursed a cheap unit along for ten years and this is what I have learned:
Nov 24, 2011 | Kenmore Top Freezer Refrigerator
Refer runs fine then freezer and fridge gets hot
Here are some things to try. I'll be the part about the radiator in back is what your main issue is:
Nov 22, 2011 | Kenmore Top Freezer Refrigerator
The refrigerator part doesn't get cold and we have frost in the freezer
I wrote this little guide for another fridge question. But I believe it may help you as well. You may have several of these things going wrong. Hopefully you don't have to actually replace anything but the heating element. Check it out and let me know if it helps!
Nov 19, 2011 | Kenmore Top Freezer Refrigerator
Water dripping in fridge
It may be condensation.
Nov 09, 2011 | Kenmore Top Freezer Refrigerator
How do you remove the face plate off of the ice/water controls on the outside of the freezer door? The spring came off the flapper door that covers up the ice delivery hole, nothing has broke, but I need...
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Sep 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water is leaking outside the door. once u open the freezer door there is ice on the bottom floor. how can i fix that
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Aug 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Leaking water from freezer side-by-side GE refrigerator
Hi, It sounds like the defrost drain is plugged. You will need to remove the rear inside panel in the freezer and unp,ug the drain. Once you remove the rear panel, you should see a collestion of ice under the evaporator coil. Locate the drain hole and clear the ice. Flush the drain hole out with hot water to make sure it will drain. You might have to run a wire through the drain or you can flush water through it with a baesting serienge.
I hope this helsp you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Refrigerators
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
248 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
