Question about Dell Computers & Internet
MOTHERBOARDS Dell p4 the board dose not power on when you press the switch even though the led on the board is lighting.
  • 22 Answers
Is it the fan of your mainboard & processor is running when u turn the power on?.. If no.. check the power supply.. it may be damage.. If yes.. try reconnect the RAM.. or even the graphic card..
Posted on Sep 15, 2008
  • marc orlando Sep 21, 2012
    Same issue. Led is lit. NO fan, NO power led, NO diagnostic leds. PSU is good. Solution please.
Display off after some time
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Jul 26, 2013 | Intel Essential DG41WV Desktop Motherboard...
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
I have a Dell Precision 620 and the problem with running a PC. When I press the button, only yellow light is present and nothing happens. Control LEDs (4 pieces) on the rear side of motherboard does not...
Having worked with Dell computers before I have found that the amber light usually means bad power supply.
Get a replacement power supply from a know working Dell machine as their power supplies are different from standard ATX power supplies.
Regards.
Jan 13, 2011 | Dell Precision 620 PC Desktop
Massive noise, now unable to access computer at all. constant amber light, not moving to next stage, nothing on screen, several thermal events previous to it blocking my access
Noise is most likely CPU Fan racing. Fault is most likely motherboard failure (Solid Amber power LED is usually MB and thermal events could be associated) Replace the motherboard
Feb 17, 2010 | Dell Optiplex GX280 (99301) Motherboard
Dell motherboard, needs power switch
look at the board it should say it at the very bottom right-hand corn and i mean very very bottom almost a ninety degree angle with the end of the board it should say panel or panel 1...2..or.3
Aug 16, 2009 | Computers & Internet
Optimized intel server board 2000 Need Diagram for
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | Intel Computers & Internet
No Power On Start
Problem Solved, changed the power supply with a 450watt one and it booted fine .
Jan 30, 2009 | PC Chips P25G Motherboard
Dead new motherboard
Are you using a 24 pin or 20 pin power supply? Can you confirm the power supply you are using does indeed work?
Mar 06, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Computers & Internet Logo
53 people viewed this question
Alun Cox
