Question about Tascam 2488 Portastudio Multitrack Recorder System
1/4 input jacks for guitars
On my 1/4 input for the guitar on the 2488mkll portastudio it will not plug in my dean markley pick up jack that I use for my acoustic I tried to plug in my monster cable cord that i use for my bass with no luck it barely fits inside the hole made for guitars and basses.Do I have a defected input on my 2488mkll? c
  • crammottt Sep 17, 2008
    I got off the phone with tascam they said any 1/4 jack should work and that this is a defective input!!!
    Problem Solver:
  • 9 Answers
Nope....if you go to your local music store they should have an adapter for your situation.....it will cost approx. $10-$20 (depending on the company)
Posted on Jul 05, 2009
My Dean Dave Mustaine signature V will not produce any sound
It looks like you have 2 humbuckers (how many wires on each?), one 3 way selector and 1 volume and 2 tone controls, plus the output jack. Tell me how many wires on these humbuckers and what colors and I can help you wire it.
Mar 28, 2013 | Dean Guitars Dean V Dave Mustaine Guitar,...
Dean Edge 4 Bass electronics quit working
Clean the contacts on the input jack and battery jack.
Sep 06, 2017 | Dean Edge 4 Bass Guitar
My double pick up Dean edge quit working while playing. I checked the wiring and all looks good, but three is s a black wire coming from hole to center of body attached to nothing. Looks like it never was....
Make sure you have two wires soldered to the output jack on the bass. having a wire lose is not purposely put like that, for no sound from the bass then that wire is either from the pickups and connects to the pots on the bass or on the output jack. I would suggest taking it to an authorized dean dealer to inspect the wiring.
Jul 13, 2011 | Dean Edge 4 Bass Guitar
I have a dean markley promag grand acoustic pick-up which connects to a plug in stap button. when i plug in there is no sound unless the volume is turned up on the amp to the max and then a very faint...
The output of this is fairly low. Do make sure you have steel strings rather than bronze for magnetic pickups like this. Make sure this pickup is oriented per the instructions.
Jul 02, 2011 | Dean Markley ProMag Grand Guitar Pickup
I have a Frontman Fender 25R, it has a power, the auxilliary input is working (the RCA, red and white ) sound is produce, when I plugged an electric guitar on the 1/4 input there is no sound coming...
You actually have the "B" version as the original 25R doesn't have RCA jacks. Anyway, on with your problem...
I want you to do a test: With a set of headphones plug them into the preamp output and then play your guitar... don't expect much loudness, it may be very faint and will ONLY be in one of the sides of the headphones. This tests the preamp section... have the guitar volume wide open.
IF you can hear the guitar that way, then the switch contact on the PA INPUT jack (not the preamp output) is not making contact. These jacks are really poor and the problem is not that uncommon. Fix is to open the unit and increase the spring tension on the contact or replace the jack. Never use the jack as they worsen evertime you plug something into it.
Note that the failing switch symptom MAY be broken soldering in the vicinity of the jack so look for that also. And also check the soldering of the guitar input jack as that is a common problem. Always loop your guitar cable through the handle so tripping over the cable doesn't break the jack by yanking the plug sideways... another common problem.
Mar 25, 2011 | Fender FrontmanTrade 25r Combo Guitar...
Can i put my fender strat mexican guitar into number two jack on the ampI got it today not sure
The Fender Stratocaster (in common with all Fender guitars) has passive pick-ups so should be plugged into the no 1 socket.
Whilst it will work in the No 2 input socket this has lower sensitivity and is intended for use with guitars that have active (battery powered) pick-ups.
Feb 10, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
2 wires came disconected inside guitar need to know where the go.
hard to say without seeing. are the wires coming from the pick ups? Or Input jack? or?
Jan 08, 2011 | Dean Vendetta XM Electric Guitar
How do i plug my eletric guitar into an amp
Connect a 1/4" instrument cable from the guitar's 1/4" jack to the amp's 1/4" input.
Oct 02, 2009 | Dean Guitars Dean Ml79 Electric Guitar
Tascam 2488mkll echo
I just bought a 2488mkll .I have a keyboard. On my old portastudio
I had to us the headphone output of the keyboard to plug into the portastudio for a signal can I do this with 2488mkll. Also the keyboard has a midi output I'm not familiar with midi cables it's a 5 pin midi can I just plug the midi output of the keyboard into the 2488mkll input or do I need something more?
May 13, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
73 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
