If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
It is probably electronic gas valve, or safety valve that let the gas flow and shuts off immediately. Better take it to the repair shop will save yourself $75.00 service fee.
Hello whatsherfac, Chances are the water caused the inlet gas valve to stick closed.. You have a few options.. one being to remove and replace it from one you get at a parts supplier.. If you provide the model number of your maytag.. I can identify which parts are most likely casuing your problem.. The electronics for your dryer may also cut off the gas supply.. I'll need more info on the model numbert before we can get to the root of your problem.. Please get back to me and I'll try to help you..
Regards
Have you checked to see if there is an obstruction in the gas valve itself or if the solenoid is worn? If there is, it will not allow as much gas through, therefor making a smaller flame and less heat. If not, check for pinched gas flex lines either before or after the gas valve or leaks in the combustion chamber. Also take out the lint trap, seal it up with cardboard cutout with a hole in it, take an air compressor with a blowout valve on it set at about 200psi, cover your face and blow out the trash out of the internal ventilation system on the dryer. Should work better after all this. Hope this helps.
