Question about Sony KV-20S20 20" TV
Sony KV-20S20 turning off after 5 sec.
Hi, I got an old Sony KV-20S20 TV. I replaced the transistores in the HOT area and a D1877 transistor on the cold are. I replaced a small 0.47 ohm resistor befor the two transistor on the hot are. The tv can turn on but after 5 sec it always turns off. Measured the current that was 80 mA. I unplugged the ANOD and still have the same issue. What can I do?
Thx in advance
Balazs
  • NUTZ19802001 Sep 25, 2008
    Hi, I got an old Sony KV-21RS10C MODEL TV. I replaced the transistores in the HOT area and a D1877 transistor on the cold are. The tv can turn on but after 5 sec it always turns off. What can I do?
    Thx in advance
    NATH
5 Suggested Answers
  • 4234 Answers
SOURCE: sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
Posted on Jan 21, 2009
romsky79
  • 822 Answers
SOURCE: sony tv KV-27FS120, blinks 6 times, horizontal transistor is good, and driver to, can you help me?
check the memory.
Posted on May 31, 2009
SOURCE: can I use the transistor d1878 horizontal instead transistor c5148, I have the specifications for c5148, but I can not find the specifications for d 1878,someone can help me?
I have Sony TV, transistor D1878 is damage, can i use the another type for replacemen?
Posted on Apr 01, 2010
gopakumarg43
  • 74844 Answers
SOURCE: SONY flat screen will turn on green light showing but no picture. TV turns off in 5 seconds. Advice???
Sounds like display panel fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Posted on Jan 10, 2017
KV-DZ29M61 crt green light blinks 12 times hot over heet just 2minites
Hello
Its HOT [Horizontal Output Transofrmer] section circuits has the trouble. There are two possibilities for this fault. The first one is shorted HOT itsef. It can be replaced; and can be bought from most of the electronic sparepart shops at your town. It will have a number printed on it, and should benoted. Must replace with same number. The second fault is with leakey Horizonal Output Transsistor. This is the transistor that drives the HOT said above. Just repalce this transistor first. After replacing it, just switch ON the set for a few seconds; say 5 seconds or so, and check the heat of the replaced transitor. If it overheats within this time period, HOT is defective and should be replaced. OK.
Jul 18, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Transistor d1878 get over heat
i have a sony kv-2197m3 i replaced tr D1878 tv turn on,but image it's bad in horizontal seize and tr D1878 was shorted again what's the matter? chek68@gmx.fr Post Solution
Oct 11, 2009 | RCA 27F530T 27" TV
No pic on the screen,the set blew up and i replace the capitors and all the burn styy yet its turn on and no pic
If you change the capacitor...Did you clean the oil of the capacitor from its surrounding area, because due to oil it could short the components, Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
Hope this will solve the problem.
Thanks for using fixya.
Jul 24, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony tv kv-xj29m80 need to know what error code 2 means
IN THIS SONY TV KV- XJ29M80, IM FACING A PROBLEM THAT SET GOES TO ERROR MODE WITHIN FEW SEC'S AFTER GETTING IT ON, AND THE LED INDICATES 2 BLINKS AND GAP AND AGAIN 2 BLINKS AND CONTINUES..PLZ HELP ME ...I WAS FOUND THE HORIZONTAL OUTPUT TRANSISTOR BLOWN AND THE 1.2 OHM RESISTANCE ALSO FOUND BLOWN...I REPLACED THE BOTH BUT THE PROBLEM IS CONTINUE...
Feb 19, 2009 | Sony KV-29LS60 29" TV
Sony 27s42 broke the horizontal output transistor
Be sure to make sure the connection on the horizontal driver transformer are soldered good. check caps around HOT
May 23, 2008 | Sony KV-27S42 27" TV
KV-27V42 27 - 4 blinks
horizontal output transistor (HOT) check IC1751 for short between pin 4 and 6
Apr 02, 2008 | Sony KV-27V42 27" TV
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
32 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
