Question about Directv (DWO2-10024)
R15 dtv box 1 channel working only
I cannot record and watch something else at the same time
Do you have two coax coax cables hooked up on your receiver
Posted on Sep 18, 2008
I've tried to set up a Bose remote to my TV and B Ray player. I can get the programme change, menu and the channel guide working but not the volume + or - .I've tried other codes as instructed.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 06, 2017 | Bose Televison & Video
My you view box won't record and I can't watch anything I've recorded. Tv programmes working fine.
What model is it?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 03, 2017 | Televison & Video
What recording disc do I use for bdhddcombo when recording o TV channels
It is better to use the slowest eg 4X disc possible but some channels may not record due to encryption
Jan 02, 2017 | Televison & Video
My UR5U -9020L remote won't change channels or pull up the guide?
how long have have you had the remote and is this the first time this has happened and when was the last time you changed the batteries?
Nov 26, 2014 | Televison & Video
Troubleshooting tv
you need to buy tv converter box,
Jun 16, 2014 | Televison & Video
How do i watch my tv with a broken remote
You can buy a universal remote and program it to work with your TV. I have always had good luck with RCA universal remotes. You can also program the remote to run your cable/sat box and your DVD/blue ray player. You could also go to the web site of the company that made the TV and order a new remote. This would be more expensive but the remote would run all the funcitions while the universal may not.
May 24, 2014 | Televison & Video
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Akai PDP4206EA lost tuner and video inputs
Mine died after a brown out. It turned out to be the main board. They're pretty hard to find.
JE
Aug 14, 2009 | Akai PDP4206EA Television
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
Directv (DWO2-10024) Logo
41 people viewed this question
Top Directv Televison & Video Experts
john milligan
Ed
Level 1 Expert
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
