Question about HP PSC 2410 All-In-One InkJet Printer
Light flashing on 2410
The hour glass is on the screen and the on light is flashing. Can you help me please
  • Anonymous Oct 09, 2008
    Ive got all four lights flashing & ive had it totaly to bits to see if the connectors where loose...nothing same thing..PLEASE help me i dont want to throw it away
    Problem Solver:
  • 5 Answers
Unplug the printer and leave it unplugged overnight (or just a few hours), then plug it back in.
Posted on Sep 16, 2008
I have a hp 2410 and get only blinking green light and hour glass. Cant print or scan even fax.. I tried re installing the printer.. but still the same problem exist..It also makes a grinding sound once...
unplug the power cord from back of printer and than press and hold the ON button for 30 second, than release the button than connect the power cord and turn on the printer
Aug 09, 2009 | HP PSC 2410 All-In-One InkJet Printer
DOES NOT TURN ON BUT LIGHT BLINKS AND MAKES FUNNY NOISE
I am having the same problem. BLinking green light and hour glass only. hp 2410
Jul 03, 2009 | Panasonic KX-FLB801 All-In-One Laser...
Flashing green light and hour glass - performs no functions
Please perform the steps given below and check the functionality.
Bypass the surge protector
If the all-in-one is plugged into a power strip, remove it from the power strip and plug it directly into a wall outlet and see if the message still appears.
Power Cycling
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
6. Restart your computer and check the functionality.
May 26, 2009 | HP Photosmart 2410 All-In-One InkJet...
Hp 2410 just clicking
When you power on the printer.
See if the scanner light move to the right and then keep on clicking.
If this happen, the scanner head is unable to find home position.
You will have to clean the strip under the glass.
If this only start to happen recently, you could unplug the printer and wait 1 hour.
Replug in the printer will at times stop the clicking.
You can go to http://h10025.www1.hp.com
Enter c00553775 into the search block.
Click on Hp All in one how to clean scanner glass.
This will bring you to the HP document.
Jan 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Lights flashing
Try the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Sep 09, 2008 | HP PSC 2410 All-In-One InkJet Printer
On light won't stop blinking and on the display there is an hour glass
there is a pending job queued, unless this file has been released and printed you cannot removed the light from blinking. pls cancell all doc spooled on your pc and select cancell all, press the cancel button on your printer as well then turn off and on your printer
Aug 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Printer not booting up after power lose.
Hi guys. I had the same problem, but looked at this thread. I guess mine was related to the power, because when I moved my plug from a power strip to a wall outlet, it worked fine.
Jul 16, 2008 | HP PSC 2410 All-In-One InkJet Printer
Hp alll in one model # PSC 2410 photosmart. Printer makes sound as if printing then stops and timer clock stays on. . tried again after shutying it off.Same problem. please help
I have a photosmart 2410 also. I found if i unplug the printer for 15 min. then plug it in, it clears the hour glass and restores function.
Jun 06, 2008 | HP Office Equipment & Supplies
HP Photosmart 2410
por favor me pueden ayudar con los drivers de esta impresora les quedare eternamente agradecidos mi correo es dismanort@hotmail.com
Jun 02, 2008 | HP Photosmart 2410 All-In-One InkJet...
2410 printer will not print
 This is Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue related to the lights blinking and Clicking sound on your Printer. I would like to provide my suggestions on the issue.
This is an issue related to the Printer Carriage stall on your Printer. To resolve the issue, Please try below solutions.
Solution 1:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00299915&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Please open the above link and perform the steps mentioned in the web page.
Oct 22, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
202 people viewed this question
Ben Johnson
