Question about RCA TruFlat 27F520T 27" TV
Menu PCU I don't have a remote, I hit the PCU on button by mistake. fix?How do I
    Scholar:
  • 188 Answers
Here's the website with the user manual. On page 8 there is a possible solution. I hope this helps.
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Posted on Sep 16, 2008
22 822 cob lux
Chances are that you changed the input setting by accidentally touching the input button on the remote. If you press the input button you should see a variety of inputs to select from, try AV1, etc or HDMI1, etc but not TV. When it shows the cable channel it was previously tuned to, press select and that should fix it
Jul 27, 2014 | Televison & Video
How to delete ch. on my 32c11ou tv so I don't have to go thru all the ch.
What you want to do is skip the channel when using to channel up and down buttons on the remote from what I understand. What you do is press menu on the remote to open up the setup menu. Use the arrow keys to navigate. From there highlight "Installation" and press "enter". Select "Channel Options" and press "enter" and the list of channels will be displayed. Scroll through the list and find the channel you to want to see and press "enter" a check mark will appear. If you make a mistake just hit "enter" again to remove it.
Jul 16, 2011 | Televison & Video
How do i hit menu?
Hello and good day!!!
You can hit remote in two ways....
  • by the button in front, below the TV you will find and read the said button "menu"
when you hit that button of menu you will see all the settings.
  • by the button/keypad using your remote, you will find and read the "menu button" there to see all the settings of your TV.
I hope this information could help you...Thank you for using FixYa....
Please don't forget to rate my answer...
Jun 08, 2011 | Televison & Video
Vizio worked fine yesterday. today get "unable to launch com.yahoo.widgets.tv.container" when pushing the VIA button
Funny, same thing happened to me about the same time! Took me a while to figure out how to fix it. You have to get to the HDTV Settings menu and hit the Help icon. Do a Clear Memory/(Factory Default) and go thru that process, basically you go through all the settings just as you did the first time you powered up the TV. This will fix your problem.
The challnge is...how to get to the HDTV Settings menu when your VIA button only brings up the error you described? I finally got there like this: Hit the "Input" button on the remote, navigate to "TV" and hit OK (basically just select TV as your input), hit the Menu button on the remote and that will bring up the HDTV Settings menu and then proceed as above
Mar 25, 2011 | Televison & Video
My Vizio TV tells me, when I press the menu button, that it's unable to launch com.yahoo.widgets.tv.container. It worked fine last night.
Mar 24, 2011 | Vizio SV472XVT 47 in. LCD HDTV
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
Black box appears on every channel
Hi:
This black box is the close caption box, you must of turned the feature on. Go into you menu setup screen and under CC option turn off Close Captoin, or you may have a CC button on your remote that you hit by mistake, try hitting this button until it says Close Caption off.
Dec 24, 2009 | JVC AV-32D305 32" TV
Hi, I recieved this tv from a neighbor some time ago, but I don't have the remote. I use the satelite remote to view the tv. This morning, I turned it on as usual, but when ever I do I have to set the...
Hello check the cable box connections to see what type of connection you are using for television, if you are watching in HD then you might of changed the video input or source button was hit by mistake.
Dec 20, 2009 | Televison & Video
Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Oct 15, 2007 | Ricoh CL3000E Laser Printer
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
