Question about Samsung RB2155 Bottom Freezer Refrigerator
Door gasket torn
The door gasket on the Refrigerator portion has about a 4" tear in it, I have been attempting to locate on with no luck. It appears the only way is to replace the whole door. Is there any supplier for just the gasket? Samsung says it's not available through them.
  • 2 more comments
  • Saytimmer Sep 19, 2008
    I have exactly the same problem and was told the same thing.
    It is exactly the same model as yours too. I wonder if we can do a class action suit against them for shoddy and unreplaceable materials. My fridge was 4 years old in July. Tim
  • a77ssii Sep 19, 2008
    I will look into that, thanks ghappliance.
    Saytimmer, unless alot of other have the same issue I would say we're probably out of luck. Ours was bought in Oct '04.
  • Anonymous Mar 19, 2014
    I am looking for freezer gasket replacement instructions
  • VICKIE
    VICKIE Apr 26, 2014
    I MODEL RF263AEBP/XAA AND MY DOOR GASKETS SEALS ARE ALL PEELING AS WELL BOTH THE FREEAER AND THE FENCH DOORSAND MY REFRIGERATOR IS ONLY 3 YEARS OLD
  • 126 Answers
I SUGGEST YOU GET IN TOUCH WITH YOUR LOCAL APPLIANCE SPARE PARTS DEALER AND ASK HIM IF THEY MAKE DOOR SEALS TO ORDER.BACK HERE IN SOUTH AFRICA WE ARE GIVEN THE OPTION OF MAKING THE DOOR SEAL PROVIDED A SAMPLE OR THE EXACT SIZE IS GIVEN IF THE MANUFACTURE HAS NO STOCK.I HAVE ALSO NOTICED THAT IT IS THE FASTEST SOLUTION THAT SAMSUNG HAS IS TO REPLACE THE DOOR AND POCKET MORE MONEY FROM YOU THE CONSUMER.
GOODLUCK.
MOHAMED
Posted on Sep 19, 2008
Instructlions edesa fridgefreezer
Since you didn\'t say, I do not know who manufactured the refrigerator/freezer of which you write. Nor do I know the model number. Fortunately, leaking freezers leave a wide evidence trail.
If the inside of a freezer door is icing up, that usually means there is an air leak to the outside of the freezer. Warmer, moist air is being sucked into the freezer, right where that moisture is freezing almost instantly, and depositing the ice right where the leak is. So, where you see the ice is pretty much where the air is coming in. That\'s where the gasket is bad.
The part that seals the door is called a gasket. It is a magnetized rubber strip that goes around the entire door, where the door contacts the main box of the freezer. As I said, this gasket is magnetic. Close the door and carefully check the entire perimeter of the door. (that means the whole rubber strip, every inch) Where the ice is on the inside, the gasket will be torn, folded over, or defective in some other way. There can even be tears in the folds of the rubber part of the gasket. Check it all, carefully. It should be readily apparent; kinked, torn, melted, yanked, out of it\'s channel, etc. The idea is to get it properly shaped so it seals to the main box of the freezer.
If you can repair it, do so. High quality silicone caulk can seal small tears in the rubber. If not, go to where you bought it, or call the 800 number and ask about a new gasket. Look for labels and/or plates, inside the door edges, on the back, anywhere. The info is there. Find it. A freezer door will not seal without a properly functioning gasket.
After the door gasket is repaired, set the freezer to maintain a constant temperature of 0\' F maximum. Get a freezer/refrigerator thermometer at K/Wal Mart or similar store and get the temps correct.
The fridge should be 40\'F MAX. 34\'F is much better. The freezer should be 0\'F max. 10\' below 0\' F is even better.
The leaking gasket on your freezer is sucking electricity and costing you money in electric bills. The sooner it\'s repaired, the quicker you will recover the money you spent on the new gasket.
If necessary.
Good luck.
Aug 19, 2014 | Refrigerators
Tip
Refrigerator Defrost issues - Check those door gaskets
While failed defrost controls is more normally the reason for poor refrigerator/freezer performance, we can not forget about the door gaskets as being a possible culprit.
First, visually inspect the gaskets for signs of severe deformation or torn areas which could prevent a good seal. If either is suspect, replace the gasket. Also make certain that magnetic gaskets in fact have the magnets.
Next, grab a dollar bill or sheet of printer paper torn to about the size of a dollar bill. Test the gasket on all doors all the way around by placing the bill or paper onto the frame with the door open. Then, close the door, and gently pull the bill or paper out from the closed door/gasket. You should feel some resistance to the pulling motion. Test all door gaskets, all the way around. Replace any gasket which allow the paper to easily pull out of the closed door, or, figure out if there is something preventing the gasket from sealing properly.
Door seal leakage allow not only warm air migration, but moisture migration into the refrigerator freezer section, putting undo load on the cooling and defrost sections to both cool the air and condense the moisture (which is seen as frost on the cooling coils.), and melt the created ice from the cooling coil..
on Dec 11, 2009 | Refrigerators
HI what can i use to bond my refrigerator door ruber which is torn
Replace the gasket. The magnet used to seal the gasket to the refrigerator or freezer frame pulls on the gasket every time you open the door.
Jun 22, 2014 | Maytag Refrigerators
Torn door gasket
it is possible for you to change it
it depends on where you are then could point you in the right direction
Feb 08, 2014 | Miele W4840 Front Load Washer
I have a smeg fridge freezer and the fridge does not appear to be cooling enough. The motor is running permanently but no matter how far we turn down the temperature it is not enough. There was a build up...
A refrigerator not cold enough is a hassle, because you are at risk of spoiling the foods you store in there. Most often, this problem is caused by something easy to fix.
1. Faulty Door Gaskets
The door gaskets in a refrigerator ensure a sealed closure every time you shut the door. Torn or loose gaskets on the door of the refrigerator can result in a leak in the cold air. As a result, the refrigerator is warmer. Repetitive and frequent opening and closing of the refrigerator is also a possible cause, because the warm air from outside replaces the cold air in the refrigerator every time you open it.
2. Dirty Condenser Coils
Dirty condenser coils can result in improper functioning of the refrigerator. These coils are located on the back or the underside of refrigerators. If you find this to be the cause of the problem, unplug the refrigerator before you attempt any cleaning.
3. Frost-free Feature not Working
If the frost-free feature fails, it causes a buildup of frost around the evaporator coils in the freezer. This causes a malfunctioning of the evaporator fan that blows cold air around. The fan can also be damaged if it hits the frost.
4. Faulty or Incorrect Temperature Control
A faulty thermostat can lead to a refrigerator that is not maintaining the desired coldness. Check for this problem and also ensure that the temperature is set to the correct level. Normally, refrigerators are set to a temperature of about 0°C, whereas the freezer sections are around -17°C.
5. Inadequate Air Flow inside Refrigerator
A refrigerator that is loaded with too many food items can fail to maintain an adequate level of coolness across all the items kept in it. The surface items tend to be colder, and the items underneath do not become as cold. A refrigerator that has very few items in it can also fail to function efficiently. Try to ensure that your refrigerator has enough food in it at all times, but is not so loaded that the air flow gets constricted.
6. Vents between Freezer and Refrigerator Clogged
The vents between the freezer and refrigerating section blow cold air from the freezer across to the refrigerator. If these vents are clogged with ice, the air is blocked and the refrigerator does not cool down. If this is the case, you can unplug the refrigerator, wait for the ice to melt and then connect it back to the power supply.
7. Faulty Door Switch
The door switch is found on the bottom of refrigerator doors. It turns off the light in the refrigerator and resumes cooling action when you close the door. If this switch is not functioning properly, the refrigerator will not be cold and it will also be affected by the heat of the interior light.
8. Refrigerant Leak
A refrigerant leak is very unlikely. This problem can cause malfunctioning of your refrigerator. If you suspect this to be the cause, contact a service technician.
Hope this will help to solve the problem...
Aug 08, 2011 | Smeg Refrigerators
Can I replace the freezer door seal on a kitchen aid myself?
some door gaskets snap into a track and others are held on to by screws in a metal frame. you can pull the back of the gasket apart to see which you have.
are you sure that the gasket is bad? you can do the dollar bill test by placing a dollar bill between the gasket and door frame and shutting the door. if the dollar bill fits snugly and is not loose the gasket is good. However you may be able to look at your gasket and see that it is torn or warped and not sealing good.
replacing the door gasket can be a little tricky but with a little patience and some very hot water to soak the new gasket in to make it easier to work with, you should be ok.
keep the bottom of your refrigerator and freezer frames clean (this is where everything spills and gets sticky) to keep the gasket from sticking to the frame and tearing up over time.
Jul 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
How do I repair the gasket on my LG refrigerator door?
Both door gaskets are torn at the top, doors not closing. Where can I get new gaskets? How do I install them?
Thanks
Apr 11, 2010 | LG LRFC25750 Refrigerator French Door
Door gasket for the refrigerator
the best source to buy the door gasket is from:
http://www.repairclinic.com/
open the link and order the gasket or any other parts for your refrigerator. keep updated.
thanks.
Jul 08, 2009 | Thetford Norcold RV Cooler/Freezer
Refrigerator gasket cement (what is it so I can buy it)
ill assume there is a tear in the gasket? if this is the case you can mend a tear with regular clear(or white) g.e. 100%silicone. apply a little silicone n the seam where the tear is and close the door overnight allowing the silicone to set up. it will remain flexible enought to compensate for the door opening and closing
Nov 18, 2008 | Kenmore 64522 Top Freezer Refrigerator
Samsung RB2155 Bottom Freezer Refrigerator Logo
241 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
