Question about Maytag Dishwashers
Maytag dishwasher mdb7601aww program not working right. Lights on display not lighting. Push button and it reads 2 hour delay. Cannot get it to run without delay. Thanks, Bill
catriver
  • 878 Answers
SOURCE: Maytag diswasher problem
liberty, it sounds like your keypad is bad, here is your tech sheet for your dishwasher, it will give you detailed instructions for checking it out. Catriver
http://www.servicematters.com/maytag_library/docs/16026393.pdf
Posted on Jan 18, 2008
  • 1314 Answers
SOURCE: Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Posted on Jan 25, 2008
SOURCE: Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Posted on Oct 28, 2008
  • 338 Answers
SOURCE: We have a Maytag MDB7601AWW
Just inside the dishwasher usually on the bottom right in the front is a mushroom shaped "float" lift it up and down a few times making sure it ends up in the down position. if you move it slowly you should hear some clicks. do that and try to run the dishwasher if that does not fix the issue then your going to have to get a meter and see if you have 120v to the fill valve when you start the dishwasher. if you have the 120v then replace the fill valve
Posted on Dec 04, 2008
SOURCE: Maytag MDBH950AWS Dishwasher won't start
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Posted on Dec 28, 2008
My maytag dishwasher dosnt work. the delay light 2,4,6 lights just blinks. I would like to know the reset code to see if i can do a cycle run.
I pressed heavy wash 3 times and then start to make it perform a field test. It tested fine, but it stuck at 61 minutes for an hour while I was testing auto clean. Another thread indicated that the controller cable interface was getting moist.
Dec 05, 2014 | Maytag 24 in. MDB5601AWS Stainless Steel...
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Kelly
Jan 04, 2011 | Dishwashers
I have a maytag dishwasher model # mdbtt70awb quiet series 300 when you push any of the wash cycle buttons nothing works. the only button that lights up is heated dry so there is at least power there....
I had the same issue try hitting delay 1hr and start the 1hr was solid not flashing and an hr later it's running just fine. Think I need a new control panel but for now this is working.
Sep 04, 2010 | Maytag Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
2 H Flashing
Seems to me you having problem with Touch panel. 2 H means 2 hours delay. It is shows up because for some reason control panel got overheat and stock. But after it cool down it start working again.
Nov 26, 2017 | Maytag 24 in. MDB7601A Free-Standing...
Control panel lights but won't start
the front control panel fries out.. We had to have ours replaced after 7 months ... after that was replaced it only lasted 2 months... WE ARE VERY disappointed and will be calling once again tomorrow. The dishwasher is not even a year old yet!
Aug 16, 2009 | Maytag MDC4650AW Built-in Dishwasher
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Maytag dishwasher error code "1H" MWB6601AWB
The 1 H is not a fault code it is the delay time of one hour.
May 10, 2008 | Dishwashers
Dishwashers Logo
63 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
