Question about Hannspree 22" widescreen LCD Flat Panel HD Monitor
Mounting a hannspree 22''/hf229h lcd monitor
Can i mount the hannspree 22''/hf229h lcd monitor to a wall. It does not seem like the arm for the desktop is removable dont want to take apart for nothing
Jay_Sav
  • 93 Answers
SOURCE: adjusting the horizontal & vertical to be proportionate
You need to set the correct resolution for your monitor,
To do this, minimize all windows, and right click on your desktop (not on an icon). Select properties, and go to Settings on the tabs on top.
Drag the slider until your resolution matches that of the monitor. I use mine on 1600 x 1050. However if your card doesn't go that high, try either the next ones down until it looks normal, or try a driver update for your graphics card.
Posted on Mar 05, 2009
SOURCE: we have a hp m8000
that happened to me. I felt stupid when I discovered what i did wrong. I attached the monitor cable to the connector at the top of the back of the computer(where it is supposed to attach, right?) - but, there was another connector for the monitor at the bottom of the computer which had been a special "card" add on. the monitor jack at the top did come with a plastic covering which meant not to use it. i thought the covering was just a protector, i didn't know. live and learn i guess.
Posted on Jul 21, 2009
  • 732 Answers
SOURCE: Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Posted on Feb 23, 2010
  • 6 Answers
SOURCE: Hannspree will not supply XP drivers
In some systems the EDID/DDC information are not recognized because of a VGA cable. I have uploaded an XP driver for HF229H to here: http://rapidshare.com/files/401122732/HF229H.inf
Posted on Jun 20, 2010
  • 47 Answers
SOURCE: I cannot get good resolution
The resolution you should be getting is 1680x1050. Under Windows 7, right click on your desktop then open 'Screen Resolution'. If the resolution is set to anything other than 1680x1050, set it to that. If that setting is not available then it is possible that your video card does not support that resolution. This would only effect old computers. If the resolution is set to 1680x1050 but you don't have the proper resolution onscreen, try adjusting the monitor settings using the buttons on the bottom of your monitor. Hope this help and have a nice day!
Posted on May 02, 2011
I cannot get good resolution in my Hannspree HF229H, what can I do???
May 02, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
Feb 22, 2010 | Hannspree HW191D LCD Monitor
How do i attach a wall mount to the back of my 20" samsung?
Samsung wall mount bracket WMB 1900T adapts for four hole wall mounts. Fits 19" to 22" monitors. Price is $27-$42 at online stores.
Apr 09, 2009 | Samsung T200HD LCD Monitor
When I plug in my hdmi set top box my monitor says no signal
If an HDMI cable won't work, try Component Cables.
I went through the same hassle as you.
Jan 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
i found a driver for my dell latitude d800 on dell.com. the download is r105341.exe. monitor works perfectly now.
Dec 15, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree HF229H
I think that you have multiple displays enabled through your video card. Just disable multiple displays.
Aug 16, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree 22" widescreen LCD Flat Panel HD Monitor Logo
148 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
