Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp Logo
Posted on Sep 12, 2011
Pump is running all the time dont shut off - Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp
Anonymous
Level 1:
New Friend:
  • Contributor 42 Answers
  • Posted on Sep 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
42
Questions
Helped
12206
Points
94
WILL NEED A NEW PRESSURE SWITCH.
Low fuel pressure 99 cherokee classic
either fuel pump but change fuel filter first and see if it helps
Im thinking my fuel pump but not sure it only turns over when i prime it once the prime is gone it dies and i dont hear the pump when i climb under tank its a 1999 crown vic w/ intercepter 4.6l also a...
first check the fuse and relay for fuel pump. heres how to check the pump. get under car and put hand on bottom of fuel tank, then have a person turn key to on . if pump is ok. you will feel a vibration in tank. you may have to do this a few times because a fuel pump only runs a few seconds to get fuel pressure to engine then shuts off. but when vehicle is running its on all the time to supply fuel to engine.
1helpful
91 dodge ram 150 starts and quit some time starts and runs fine until i try to start it again dont matter cold or hot replaced fuel pump
There is a box under the hood next to the battery with fuses and relays.
there is a fuel pump relay and or Auto shut down relay that could be bad.
It shuts down the entire system ignition and or fuel pump.
ASD Relay.
2answers
1998 Plymouth Breeze not starting sounds like it wants to but wont catch
Maybe one of two things.....timing or fuel delivery. Check fuel pressure. Maybe a fuel pump which can be costly.
Fuel pump runs and dont run at times wont start
First thing would be to either test or replace the relay which is under the hood. Do check the fuse as well. you can test power to the relay and also to the pump with a voltmeter. You can test the relay itself with an ohmmeter.
2answers
Car will start,run for two good seconds and then die.can fuel filter be blown out? dont have the lunch money to get new one at the time.
no, its not a filter issue. Most likely a fuel pump issue. Spray brake cleaner to see ifit will run while spraying sparingly. If it keeps running then the fuel pump failed.
2helpful
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
No start when hot
ignation control mogule,wen get hot expend and lose conection and will not start after cool down start normal also will cose no fuell presure fuell pump will not run,locatiom under coils.replece it
Fuel pump will not prime..
Are you even sure it was the fuel pump to begin with?
All electric fuel pumps shut off after the key is turned on in just a few seconds.It will only run as long as the car is running. So it makes me think that the fuel pump was ok to begin with. You probably need to change the ignition module. Its the flat thing that the wires plug into on the side of distributor. Let me know what happens
Top Sta Rite Industries Garden Experts
Jay Finke
Jay Finke
john h
Thomas Perkins
Thomas Perkins
Are you a Sta Rite Industries Garden Expert? Answer questions, earn points and help others
