Question about Canon Pixma iP4500 InkJet Printer
Ink cartidge problem
My printer is only 5 months old. Have used it, maybe 4 times, without any difficulty. Now, when I try to print, the message that one of my ink tanks is empty comes up and cancels the job. When I check inside the printer, the light on the cyan ink tank is out. When I remove the tank, it is obviously FULL, so I place it back and try the job again. The same error message continues. I've tried unplugging the printer and resume...same results. It is hard to believe that the ink tank is empty, and it LOOKS full.
Any ideas?
  • 1 more comment
  • lildinger2 Sep 15, 2008
    I tried your suggestions without a solution. I DID pay closer attention to the alarm lamp this time. It flashes a consistent 15 flashes, stops for a split second, then 15 flashes.........
    And other ideas?
    Thanks!
  • carmat694 Oct 26, 2008
    Hey! I too have the same problem - printer only a few months old and all of a sudden I cannot print and the light on the cyan ink is out, but the cartridge is full. I hear the click when I replaced it back in and will trbuy another one tomorrow when the shops open.
  • kavlinna Mar 03, 2009
    I'm facing the exact same problem with the ink cartridge too! The alarm light keeps flashing and the message keeps telling me to "Check Ink", saying that the Cyan cartridge seems to be out of ink. But when I checked the Cyan cartridge, the ink is still full, cos I just replaced the cartridge a week ago ....
    I'm finding this Canon printer such a disappointment, cos it can't print and can't even scan a document for me cos of the problematic Cyan ink cartridge.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
This proposed "beginning" solution assumes that you have already done one important thing. The printer will dislay the exact characteristics you have described if the ink tanks are not placed properly or are not in the correct order. I recognize this is a very elemental step, and no offense is intended, it is just that these basics should all be verified as it is easy for us to overlook the obvious!
Now, in accordance with your manual, a quickly repeating circular light (1-second intervals) is the indicator of the tank being either in the wrong position, or it being empty. The state of the ink lamp being off entirely - which is what you have stated - is intended to indicate that the tank is not set properly. Press the PUSH "icon" on the tank until you hear it click into place. I would suggest that if it does not click on the first or second try, you remove the tank and entirely reseat the tank, verifying again that all packing materials have been removed. (Always be careful not to touch any of the electrical contacts, as this may render the tank unusable.)
Perform print head cleaning. This is a three-step progressive process - in other words, if step one works, you can stop there. If your manual does not provide adequate instruction on this approach, go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=15596#SupportDetailAct, which is the Canon USA site. Canon typically does not allow going straight to the page at hand, so you will likely have to type in what you are looking for under the "Support & Service" tab. The name of the particular article focused on this process is "Performing Nozzle Test and Head Cleanings - Windows".
Canon further indicates that the print head may need to be replaced, or that the system may need to be repaired (by an authorized tech, of course...). If this is the case, given the length of ownership and extent of usage, you should be able to get service under warranty. One final question, in case we have not yet found resolution for you. When there is an issue with a printer component, e.g., an ink tank, the alarm lamp, which is directly below the power button on the right front corner of the unit, should be flashing orange. The number of these repeated flashes (for instance, three consistent flashes, pause, three more, pause, etc., all the way up to 16..) gives us guidance as to the actual problem. Additionally, do you use the printer status monitor, which gives you details regarding the printer's status and information regarding other items? If so, would you relay what is shown in the monitor, in addition to what is occurring with the Alarm Light.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 15, 2008
  • Cheryl Whalen Sep 15, 2008
    Given that I wrote the original response for you in the middle of the night (our night at least), I hope that most of it was intelligible! I wanted to make sure of a few things. You previously stated that the ink lamp associated with the cyan tank is out completely - right? If so, per the manual for this product, this indicates that the cartridge is not seated properly. It does not mean that the cartridge is low or out of ink. Did you reseat it and if so, did it actually click into place when pushing on the "push" icon? Also, these are new, factory ink tanks, right (not refilled or refurbished)?
    Given the emphasis Canon places on all ink tanks being placed in the proper order, perhaps it would be worthwhile to remove all of them (one at a time, noting that they are kept in the correct order), and then reseat one at a time. In other words, do not remove more than one from the machine at any given point in time. However, this should also allow you to confirm that placement is appropriate, as each tank should light as it is reseated. (However, there is a risk to this, as noted below, due to the Canon notation that placement of partially filled ink tanks result in the inability of the printer to monitor the ink levels.) If this does not work, I would suggest that you might have a defective cyan ink tank. Replace it with a new one - if it doesn't work to rectify this problem, you could either hold it in reserve or return it.
    Canon also indicates that if pushing it in until it clicks doesn't work, "there has been an error and the printer can not print." (There's a news bulletin - huh?!:-) Presuming that there has been no change in the ink tanks since you previously utilized the printer successfully, it is not likely that there is packing material (tapes, etc.) inadvertently remaining on the tanks.
    Do you use the printer status monitor, which is the software that communicates with the printer? I ask this because that software could give us further information regarding the specific problem at hand. Additionally, and this is common, ink tanks are known to dry out (and/or malfunction because of this) when the tank is used for more than about 6 months. Canon also indicates that a partially full ink tank should not be placed in the machine once it has been removed, as the system is unable to determine the status of ink within that tank. If we can get the system to a printing state, it will automatically perform the printhead cleaning upon the first printing following replacement of the tank.
    Following is the information from the Canon manual for this printer in regard to 15 and 16 flashes of the alarm lamp:
    Fifteen flashes: Ink tank cannot be recognized.
    An Ink tank error has occurred. (The lamp on the ink tank is off.)
    Replace the ink tank.
    See Replacing an Ink Tank.
    Sixteen flashes: Ink has run out.
    Ink has run out. (The lamp on the ink tank flashes.)
    Replace the ink tank and close the Top Cover.
    Printing under the current condition may damage the printer.
    If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the RESUME/CANCEL button for at least 5 seconds, and then release it.
    * With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any malfunction or trouble which may be caused by continuation of printing under the ink out condition.
    Note
    If the function for detecting the remaining ink level is disabled, the ink tank is displayed in gray on the printer status monitor (Windows) and Canon IJ Printer Utility (Macintosh). See Getting the Ink Status Information.
    As you can see, 15 means there is an issue with an ink tank. I really think the best bet is to get a new tank for that one, and see if it doesn't solve the problem. This assumes, of course, that you have heard an audible click or snap when pushing in on the existing tank. Please let me know how this turns out. Based on your feedback regarding the individual steps, we are trying everything possible from the user's end. You can not really go further into the machine without voiding your warranty. I look forward to hearing back from you - and hearing that it is printing up a storm!!
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
How to reset the Canon MX850 Printer, after ink change and counter reset? After I had changed ink cartidge and reset ink counter, I was able to print without problem. But this was only for a few days. ...
One way is to hold the 'Stop/Reset' button for at least 5 seconds until the display shows a new message about ignoring the current ink condition. This does not reset the chip but it does allow you to continue printing with the refilled ink tanks.
Mar 04, 2009 | Canon PIXMA MX850 Multifunction Printer
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
2. Open the scanner.
3. Open the cartridge cover.
4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
7. Remove the yellow tape from the bottom of the cartridge.
CAUTION:
Do not remove any other labels or seals, or ink will leak.
8. Insert the new cartridge into the holder and push it down until it clicks into place.
9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
10. Close the scanner.
11. Press OK to begin charging the ink. This takes about 2 minutes.
When you see a completion message on the LCD display screen, ink charging is finished.
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
Printer stopped printing in the middle of a doc
Have checked the ink cartridge to see if it is empty? Sometime the the inki will run out and not display on the motitor. Have had this happen to one of my friends and that was the problem. Hope this helps. Bud
Jan 03, 2009 | Office Equipment & Supplies
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
HP Deskjet D4160
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your issue and I would like to provide my solution on the issue.
Well, this is the issue that could happen with either with Printer Software or with Printer Ink cartidges that could be out of ink or very low in ink...
To isolate and to resolve the issue I recommend you to perform below solution. I hope that this will fix the issue for you.
Solution 1: Hard Reset Printer
1. Turn OFF printer
2. Disconnect Printer from Computer.
3. Remove the Printer Power Cable from wall outlet and then try to remove the ink cartidges from Printer.
4. Wait for a minute.
5. and then reseat the Printer ink cartidges and then Connect the Printer cable to the Computer and then Power ON Printer.
This should generally fix the issue. However, if the issue still persists then I recommend you to proceed further solution on the issue.
Soltution 2:
Right click on the Printer icon of HP Deskjet D4100 Series and then select the option " online " and then press F5 key in the keyboard. to effect the changes.
Solution 3:
Try to print a Cartidges Test page from Printer Properties to check the ink cartidges ink status.
if found issue with ink cartridges then replace them else try to uninstall and reinstall the Printer software.
This should resolve the issue. If the issue still persists then I recommend you to contact HP CHAT SUPPORT or HP PHONE SUPPORT team or HP EMAIL Support on this issue. They can help you further to resolve the issue for you.
If you need any further assistance you can mail me at thumuvikram@rediffmail.com. I 'll be glad to help you ...
Bye.
Mar 27, 2008 | Apple HP DeskJet 3820 InkJet Printer
Printer is not printing black
Remove cartridge and remove the mains from the wall.
Try cleaning the contacts with a cloth dampened WITH WATER, wipe it up with another cloth and let dry.
If your old cartridge is not working again, try with a new one, generally is the cartridge which may become damaged, not the printer... hope !
Dec 31, 2007 | Lexmark X1150 All-In-One InkJet Printer
Error e5
Isnt e5 error meaning the cartridge has been previously used before?? Best bet is to hold in both the colour and black copy buttons for about 5 - 10 seconds and this should allow you to print again. If you do not have a copier/scanner, hold in the resume button. (triangle within a circle).
Sep 11, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma iP4500 InkJet Printer Logo
527 people viewed this question
old marine
old marine
