SOURCE: can't get charger cord to stay in phone to charge
I would recommend stopping by the shop you bought it at, or a cell phone accessory store. They will usually (more than likely) let you test out a charger, as it could be simply wear and tear on your charger. Doing this will address your problem as it will let you know whether in fact it is the charger, or the phone itself.
Good luck.
SOURCE: The charger port on my lg voyager is frayed. If i
you have done well in troubleshooting it. if you have tried another charger on it and its not charging, then you have to replace the charging port. if you are good opening phones, then replacing the charging port will not be a problem. the chrging port is usually not screwed, it is just fixed to the board by contacts. look for the replacement part and change it. other wise, take it to a phone technician with the new charging port and replace it. good luck!
SOURCE: lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
I took out the battery on a lg verizon phone oops put it back in now black nothing ?? There must be some sort of way to replace the battery that reinitializes it any help
SOURCE: how do i resolve the error: use genuine battery. power off
A temporary fix to the problem is to put the battery in the freezer for a minute and then put it back in the phone and it will turn on just fine! I had an LGVX8700 and it just randomly started happening one day and my fiance told me to try doing that so i did and sure enough it worked. I had to go to verizon at one point to get a new phone because the one i had got damaged and the tech there used the same battery in my phone for the new one and he thought i was crazy when i told him to put the battery in the freezer but he was in for a surprise when he did what i told him and my phone turned on. It's annoying because you have to do that everytime your phone shuts off but i always made sure i plugged it into the charger before it went completely dead.
