Question about Video Cameras
Tape eject I have a old sony handycam video 8 and the tape will not eject.I do not want to take it apart because i do not know what i am doing.I hope you can help
I have the same camcorder SONY DCR-TRV130 and have had this same problem.
The first time this happened, I was able to eject the tape by turning the unit to VCR, removing the battery then putting battery back in and pressing the blue eject button. Now 2 years later, same problem only the same solution did not work. I read many other solutions, and found one I had not yet heard of. They mentioned using a straight edge..... I was confused, but learned that the point is to try to press the blue eject button without having to completely open (lift) the door. I was able to use a strong paperclip (opened up or unfolded) I reached in with the paperclip and applied pressure to the blue button and as soon as I heard the "gears" turning, I lifted the door and the tape ejected.
Try it, I was very surprised that it worked. This has been a problem for me for about a month. I am pleasantly surprised to have a solution. Hopefully it will work for you too!
Posted on Jan 16, 2009
Try this: remove the battery and any external power supply. Look around on the camcorder for a memory battery port. They are sometimes well hidden. Some camcorders did not have them. If yours has it, open the compartment and remove one of the batteries (hearing aid type small button-shaped cells.) notice which side faces which way when you remove it. Wait a half minute, put your main battery back in and see if the cassette drawer will open. Sometimes you might need to recharge your main battery before it will work. Sometimes it takes several tries to get it to open all the way. If successful, re-insert the memory batteries. The memory will retain any fault information and will shut the camera systems down whenever you try to operate it until you reset the memory by removing the batteries. If it doesn't work, repair shop time!
Posted on Sep 15, 2008
I read this on another site and it worked:
Open the top cover about 25 degrees or less and hit the blue eject button with a paper clip or hair pin.
It worked!!!
Posted on Apr 29, 2009
I cannot get the tape out! Please help! My daughter's recital is coming up! thanks!
Posted on Dec 07, 2008
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Mar 28, 2010 | Sony Handycam CCD-TRV43 Camcorder
Sony ccd-trv43 showing c:32:00?
Error Code = C:32:00 - Tape will not eject... I found that the Camcorder ate the tape and the tape was rapped all up inside the Camcorder, preventing the tape from ejecting. I took the Camcorder entirely apart and removed the tape manually and re-assembled the Camcorder. When finished there were no extra parts or screws and my Camcorder works perfectly once again. However, I DO NOT RECOMMEND this procedure if you are not confidant that you can disassemble and re-assemble your Camcorder.
Dec 05, 2009 | Sony Handycam CCD-TR416 Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
My handycam sony steady shot , the tape deck will not open
Try using the battery charger while attempting to eject it. The battery, although you may not know it, probably cannot supply the power needed to open the tape deck. If it makes a little Ding sound when you press the eject button, that means it is trying to eject the tape. Hope this helps!
Jan 25, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony Handycam DCR-TRV330 Digital-8 won't calibrate tapes to be able to view
hi there. i just actually had this problem right now. and heres how i fixed it :) it had the error so i took out the tape left it ejected for about 5 seconds. then put the tape back. it read for a little then errored again so it was close. next what i did is plugged the camera in (last time this error happened i plugged in the power and it fixed it) still no fix so i took off the battery waited 5 seconds then put it back on. after that i ejected the tape again and re put it in and it worked! you could try anyone of those things. and usually they work for me. maybe it has something to do with the cameras being old.
Sep 16, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Jul 24, 2008 | Sony Handycam CCD-TRV37 Camcorder
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
Video Cameras Logo
786 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
