Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Gold does not spin. No error code.
Whirlpool gold washer does not spin. It works well before my wife put a heavy load to it. I suspect that it may be damaged by a "Heavy Load". Other than not Spin, Everything else (wash, rinse..) works well. When spin, the inside tan does not move, motor at the bottom of machine make a loud sound.
How should I check, is coupler broken?
Appreciated if any helps.
  • emmsvs Sep 22, 2008
    Have same type of washer. Whirlpool Gold top loader. All works except spin cycle. I can get it to work if I turn the dial to the wash part of the cycle. I hear the drive kick in. Then I advance the dial to spin and it works. Not sure what the problem is either.
  • Anonymous Feb 09, 2009
    My tenant is telling me that the washer works fine until it gets to the spin cycle. He then give it a nudge and it seems to work fine but with lighter loads? Thoughts? Easy fix? Thanks
  • 324 Answers
Sounds like the 2 posts are differant. harrison2008 if the coupler is broke it won't check it you lean the machine back and look at the motor and gearcase the coupler is right between the can try turning it by hand with the machine unplugged and it may fall off.
Posted on Nov 05, 2008
Water leaking from bottom of machine when water is going into the load
I suspect that the hose reaching from the water control solenoids to the fill spout is loose or damaged.
Aug 04, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My front load has a f 6 code flashing
F06 is an error code that meansthat the control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Read more: Duet Front Loading Automatic Washer Fault Codes#ixzz1goJUbb8i
Dec 05, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Gold Ultimate Care heavy duty Washer - no spin cycle in any setting. "whirring" noise but no spinning action
The problem more than likely is the coupling to the motor and transmission. This is a common problem with these machines and it should only cost around $ 100.00 to repair, make sure that you replace the plastic tabs in the agitator also, these should only add about $10.00 to the repair and they wear out about the same as the coupling. These can be done yourself if your mechanically inclined, but most prepair places give you a warranty with their work.
Nov 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ghw9150 help !!!!!!!
I would run the drain hose into a bucket or the sink to make sure that it is not your plumbing if it still gives you the code replace the pump just because this pump is putting out water doesn't mean that it is doing it as fast as the machine wants it too. Those pumps are not that reliable and have tricked me a couple of times until I replaced them. good luck.
Dec 27, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Spinner will not spin in whirlpool gold washer.
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!!
Nov 17, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet HT Has F error & won't drain & spin
I agree a F code of 21 or 2 I would clean the pump and check the bellow behind as well the pump entry from the trap for debris or a broken impeller.
Sep 08, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool gold washing machine
It is either a timer issue or a motor issue. I know, that you knew. But if you have a motor with like circuitry and size, you can try that or to put it into the spin cycle and see if it is a mechanical obstruction or with a voltmeter see if the timer is working.
Apr 19, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
322 people viewed this question
Dan Webster
Dan Webster
Sal De
