Question about Electrolux Dishwashers
Please advise how I can safely remove the water and energy rating labels from from my Dishlex DX103 dishwasher,without damage to the paint surface. The labels are stuck firmly and can not possibly be peeled off.I would very much appreciate your help. Thank you, Heather Jenkinson
  • 706 Answers
Hello Heather,
Most labels can be removed with isopropal alcohol without affecting the painted surface.. Try a small amount on a clean cloth to verify that it doesn't 'cut' the paint.. ..but that should work for you..
Posted on Sep 15, 2008
I need to buy a new cutlery basket for dishlex DX103 where can I get one
Might find a comparable one here.. http://www.ebay.co.uk/bhp/dishwasher-cutlery-basket
Jan 02, 2017 | Dishwashers
Tip
Make gaskets easier to remove with common household product
Any mechanic will tell you; scraping away old gasket material from gasket surfaces ranges from tedious (at best) - to downright hazardous to both man and machine. The ever present risks are razor blade injury to hands - and similar damage to the gasket surface being scraped clean. Neither are pleasant.
There are a number commercially available gasket removal products - and they all work great, but they're not usually nearby when needed. What I have found to work equally well - and is usually only as far away as my kitchen: oven cleaner. The aerosol variety made by Easy Off is my personal favorite. First remove as much of the remaining gasket as possible by pulling on it or light scraping. Then spray the oven cleaner on, let it sit for about 15 minutes, and scrape away even the most stubborn, baked on gaskets, with ease.
Of course, you will want to observe all of the precautions on the product label. And be advised: oven cleaner will damage painted surfaces. Use of this product - along with a sharp-edged gasket scraper - will not only save you time and (possibly) physical pain, but will also lower the potential for inflicting damage to the gasket surface.
on Apr 11, 2010 | Motorcycles
How do I recoat my microwave?
I assume you want to paint it. Preparation is the key. Rustoleum has some pretty good products that look close to stainless steal. Clean the outside thoroughly. The paint will only stick well to metal surfaces. Plastics will tend to crack and peel. Tape and paper off all the parts of microwave not being painted. You will not want to get paint on labels, keypad, plastics or the door seal. Paint takes and hour to dry between coats. Practice with long strokes on something else first. Several thin coats is better than one thick one. Fumes can be strong. Outdoors without wind or a garage will be the best area to paint. Paint is oil based and you will need paint thinner( or WD-40 in a pinch ) for cleanup. I don't think painting would be wise inside the microwave. I painted my range hood, and I swear it looks like its stainless steel. I used the brushed nickel color. Good luck.
Apr 12, 2014 | GE 24 in. Profile PDW7880G Built-in...
Not drying
no heat? test element and circuit from control board.
If Dishlex DX103 etc, resolder relay onto board and get quote on new control board.
Oct 17, 2013 | Dishwashers
Painter has left small line of white vinyl matt emulsion (from ceiling -no masking tape used ) along the top left hand edge of the new stainless steel cooker hood - out of eye line but visible. how can I...
Luckily, vinyl matt emulsion paint is water based and is fairly easy to remove. Use half a wooden garden washing line peg or similar piece of softwood with s mild solution of washing up liquid. The wood will rub the paint off the metalwork and the washing liqid will lubricate without the metalwork so not to damage it.
Hope this helps.
Nov 25, 2010 | Microwave Ovens
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
I want to download a Dishlex DX103 dishwasher manual
want to know as this is my first dishlex dishwasher dx103. As there is no instruction manual being a rented property i want to know how to get solution on my problem. Was working last night but went to put a load on this morning but now have lights and thats it no cycle please help.....
Sep 19, 2009 | Electrolux Dishwashers
Dishlex global 500 rinse and wash problem
This was due to a faulty pump motor which I have now replaced.
Jan 10, 2009 | Dishwashers
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Dishwashers Logo
127 people viewed this question
Top Electrolux Dishwashers Experts
Electrolux
Electrolux
Mike Cairns
Mike Cairns
Mike
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
