Question about Kitchen Ranges
GE spectra Gas Oven XL 44 : self clean mode door does not seal shut
When i self clean, and manually move leaver to right to lock door., house reaks of gas and I think i see smoke. upon investigating it does not appear the door closes completely or is fully sealed when self cleaning only . self clean leaver (when locked) and moved to the right is not complete to right, its sought of 75% there - not tucked into the right as it does to the left when not in self clean .
door seal well when in standard cooking mode , only problem is self clean, its almost like the lock leaver when slid to the right keeps the door from sealing .......................door does lock and cannot move leaver until oven cools
Is this a fix for a novice, im not too handy but can do anything under direction., i would like to fix myself - got laid off from my job three weeks ago
thank you to anyone considering to help
terence mcginn
terencemcg@yahoo.com
856 430 0549
any suggestions would be greatly appreciated - oven door closes and seals when cooking just fine
  • 213 Answers
SOURCE: GE XL 44 GAS OVEN
there is an ignitor called a glow bar in the oven if its gone bad or just gotten weak the saftey valve wont open to let gas in so it wont be able to light. replaced the glow bar
Posted on Nov 26, 2007
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
  • 22 Answers
SOURCE: Manual lever to lock self clean oven wil not lock
After sliding latch to its locking position did you press the self clean button on the control panel?
Posted on Mar 31, 2009
SOURCE: How do I clean a GE gas range (self-cleaning oven?)
What do i clean the burners with ? the round surfers is harder to scrub, what do you advice .
Posted on Jun 22, 2009
heatman101
  • 43501 Answers
SOURCE: After cleaning my GE XL-44 self cleaning oven, the
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on May 14, 2010
After cleaning my GE XL-44 self cleaning oven, the door lock wouldn't unlock when I moved the lock lever back to the left. i moved it back to the lock position and tried again, and the lever broke off in...
heatman101
May 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 self cleaning gas oven willnot come on
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Feb 20, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44 after self clean cycle the door won't open and the display says "locked door" flashing.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Sep 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool Stove Self Cleaning Oven mechanism won't shut off
pull the power cord it should hopefully un lock the magnetic lock
Jun 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I don't remember how to use the self cleaning feature
Remove everything from the inside of the oven, lock the door if your model has a latch handle that you move from left to right to lock the door, then set the oven selector switch to clean.
Dec 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
119 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
