Question about Cell Phones
Ipphone will not turn on - Cell Phones
    Problem Solver:
  • 19 Answers
If you can hook it up to your computer set it into recovery mode. Update firmware then remove from recoverymode then it should work. I think
Posted on Sep 15, 2008
The hazard back lights wont quit blinking when car is running even when i pull the fuse on a 2002 buick regal
What fuse are you pulling ?
Hazard Lamps
The hazard warning switch is part of the turn signal switch. The turn signal switch receives battery voltage at all times through the HAZARD SWITCH Fuse. When the hazard switch is placed in the HAZARD position, battery voltage is applied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher sends a turn signal flasher signal to the turn signal switch. The turn signal switch provides all of the turn lamps and turn indicators with the turn signal flasher signal, simultaneously flashing them on and off.
Turn Signal Lamps
The front turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL Fuse. Battery voltage is then applied through the turn signal fuse circuit to the turn signal switch. When the turn signal switch is placed in the LH or RH position, voltage is supplied to the hazard lamp/turn signal lamp flasher. The hazard lamp/turn signal lamp flasher supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the BCM. The turn lamps are permanently grounded.
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column - Tilt.
Feb 11, 2017 | Buick Cars & Trucks
Passenger side turn signal flashes faster but dont work even at day runing light, comes on when head lights are on, replace bulb and socket because was melted but stilldoes the same
Turn Signal Lamps
The turn signal lamps may only be activated with the ignition switch in RUN or BULB TEST position. The T/SIG fuse supplies ignition voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, the turn signal switch sends an ignition voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. When the turn signal switch receives the on-off signal it will send that signal to the following lamps on the LH or RH side:
The Rear Turn Lamp
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
Oct 11, 2015 | 2001 Pontiac Montana
Turn signals wont turn off
my turn signals turn on ok but won't turn off after the turn is made, I have to manually turn them off. is this a fuse problem or could it be something else
Jan 03, 2014 | 2007 Pontiac Torrent AWD
PC Port stops working
Class of service option disable PC. Port. Or the the hp port is not tagged/untagged to the wrong vlan.
Oct 16, 2013 | Mitel 5212 IP Phone
I need to reset the mitel 5212 IPphone passcode as the previous employee has left can you advise how I do this please as I need to set up voicemail
Hello...if u have access on mitel system then u can goto user configuration form then select extension# u want to edit...from there u can even delete the mac address and more..hope it helps
Nov 04, 2009 | Mitel 5212 IP Phone
Please help. I can´t do a forwarded call. It doesn´t work. If I make a redirection on other number and than I call this redirected phone, they are both quiet and also there is not a dialling...
There could be several causes:
1. The forward number you entered is wrong.
2. The phone you try to forward the call to is not working.
3. The Voip Switch does not allow redirect.
Sep 02, 2009 | Linksys SPA942 IP Phone
Converting to SIP
connect a crosscable between your cisco 7940 and the laptop
start a dhcpserver and a tftpserver on your laptop
The files i mentioned (SIP license) have to be purchased at Cisco.
start the IPPhone, thats all
Aug 26, 2008 | Cisco 7940G IP Phone
3crgpoe10075 status led blinking with no stop
hi ,,, i got yor problem. as ya said its not allowing ya to log nto it with security enabled. Ya can try to log into it with the ethernet cable as their wil be an ethernet LAN port onthe access point. I f ya know the default or the present ip of AP then ya can assign a static ip of the same range to yor computer like eg. ap is 192.168 .1.1 then your comp can have 192.168.1.10 and ya can log into it thru the ethernet cable and disable the security. i hope ya know how to assign a staic ip add to yor compuetr. or check the screen shots on brivers.com n select the "network connections" screen shots to assign a static ip address to yor' comp. feel free to chat with me on samrat101 thru yahoo or msn messenger or drop a mail on samrat101@yahoo.com for ny wless n ipphone issues -- take care ,, samrat
Nov 23, 2006 | 3Com OfficeConnect 802.11g/b Wireless...
Cell Phones Logo
Top Cell Phones Experts
William Alequin
meteshadow
Are you a Cell Phone Expert? Answer questions, earn points and help others
