Question about Hitachi 51SWX20B 51" Rear Projection Television
Hitachi 51swx20b I had problems with colors shadowing objects. I am assuming and hoping that I needed to replace stk 392 -110s. I also read that I should upgrade to the 180s. I have the circuit board 90% out but cant seem to get the color guns disconnected from board. Additionally, the two items that say stk 392-110 are screwed to these two big fin looking things. Does that all come out? Also I read somewhere that while I had the board out I might as well replace IK04 and IK05. I see the numbers but not sure what is what. Maybe I should just order and see what they look like whne they get here. Thanks, kevin
The fin looking things are heatsinks. You'll want to unscrew the chips from them and be sure you have some heatsink compound for the new chips (get it from Radio Shack or a computer store).
I don't have a Hitachi, but I'd guess the other parts you're referring to are resistors. Get yourself a multimeter and measure the resistance of each to ensure they're within tolerance (each one should be marked with a resistance value).
I don't know about the disconnection question. On my Panasonic, the color guns were connected by small connector blocks and easy came off. Be sure to label any connectors you take off to ensure you put them back on the same one. Might want to take digital photos, as I did to help.
Posted on Sep 15, 2008
Shaded color tinting everything in pink and green. I've tried Magic Focus (5). It's a Hitachi 51SWX20B.
sound like a common problem where the coolant for the tubes has become contaminated. It is possible to replace the coolant yourself and can be a much cheaper alternative to getting repair shop to fix.
do a search for replace coolant 51swx20b
Oct 21, 2013 | Hitachi 51SWX20B 51" Rear Projection...
Colors are crooked on screen
see previous answer to this--set will need the two STK-392-110 OR -150 CHIPS REPLACED.
Not open heart surgery and not that expensive parts wise.
SD TECH
Apr 25, 2012 | Hitachi 51SWX20B 51" Rear Projection...
On the screen I see on the sides of every object a shadow, it,s green on the left side and red on the right side accompanied by some little horizontal red stripes. It started doing it all of a sudden a...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
Why am I getting a blue ghosing shadow behind the objects on my TV?
Ur have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergnce board have dead 2 STK convergence ICS and some or all it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | Hitachi 57F500 57" Rear Projection...
I just turned on my tv and there are shadows around everything on the screen. Purple ones on the left of the object and green on the right. I was just watching it last night and now it's doing this. ...
Very common problems with the DLP projection tvs.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Hitachi 53UWX10B 53" Rear Projection...
There are blue shadows around heads, much of the print is in yellow
The tv have a problems known as Convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 20, 2010 | Hitachi 51SWX20B 51" Rear Projection...
The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from www.TvRepairKits.com
Jan 10, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Model 51swx20b---bad colors and shadows in blue
NEEDS CONVERGENCE REPAIRED EST AROUND 300.00 CALL TERRYSTV IF IN N. CALIF
Apr 12, 2009 | Hitachi 43F300 43" Rear Projection...
Hitachi 51SWX20B 51" Rear Projection Television Logo
90 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
