Sunpentown WA-1220E Portable Air Conditioner
Problem for Sunpentown WA-1220E Portable Air Conditioner
Leaking portable A/C unit...
By Metal Zone on Sep 15, 2008
I have an SPT WA-1220E Portable A/C unit that is leaking when running. It will auto shut off when it detects it is full, but Im wondering if it is filling before it shuts off...? It has a rubber plugged release tube where I drain the water, it drains fine and is definitely not plugged up. I also tip it backwards to get every bit of water that will come out of the drain. I then replug the drain tube. I turn it on, it runs perfectly, cools the room, then an hour or two (sometimes more...) goes by and when I check the area the right side (when facing back of unit) is starting to leak water from the bottom of the unit. Near as I can tell it seems to be coming down from the back right wheel area. Im tired of towel drying and using a hair dryer to dry the carpet. This thing runs fine, it cools the bedroom well. I purchased it used and have no manual and know nothing about A/C units. But, Im on the verge of taking the outside covers off, to see if it has a loose hose or a bad water detection sensor, if there is such a thing...? Would appreciate any assistance !
Popular Solutions for Sunpentown WA-1220E Portable
Questions and Unsolved Problems for Sunpentown WA-1220E Portable
Do you recommend Sunpentown WA-1220E Portable Air Conditioner?
Answer
Answer
My comfort Zone II has stopped displaying the third zone. What could be the problem?
Answer
My dehumidifier runs but does not extract any water.
Answer
portable sunpentown air conditioner/heater blows non heated or cooled air. after cleaning coils, red... (More)
Answer
my power light is flashing. and the unit won't come on what can I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sunpentown WA-1220E Portable...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
