Question about ASUS P5P800-VM Motherboard
Sudden Shutdown My computer shuts down quickly after i turn it on (it lasts between 2 seconds and 1 minute, randomly). I could see a warning about overclocking settings which i tried to undo (i haven't done that and i don't know even how) but i'm not sure if i made it alright. what could i do about this? is there a way to reset bios/setup settings? what other things can cause sudden shutdowns? The motherboard is an asus p5p800-vm
Hi, I am Sanja and will try to help you.
Try to remove battery from your motherboard, and power cable from computer case. Leave it for about minute, and then return battery, power cable and try to turn on the PC.
You should have no trouble in identifying battery, it is pretty much standard, if you have more questions please do post them
Regards, Sanja.
Posted on Sep 15, 2008
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Tip
Here's how to create a shutdown shortcut on your desktop
Instead of going to the start menu, choosing shutdown, then waiting for the computer to shut all the programs down, you can create a shortcut on the desktop to do it quickly. You can create a shutdown, restart, or a logoff icon on your desktop which will work a lot quicker than using the usual buttons in the start menu.
1. Go to your blank desktop
2. Right click on a blank space and a menu will appear
3. Choose New from the menu
4. Then choose Shortcut
5. Where it says type the location of the item type in shutdown.exe -s
6. Then press next
7. Now enter a name for your icon. Mine is called SHUTDOWN NOW
8. Press next
9. The Shutdown shortcut will be on your desktop
Different combination you can type in when creating a shortcut to shutdown, restart, or logoff.
Shutdown.exe -s
Shutsdown your computer in 30 seconds and will close all programs and ask you to save all work.
shutdown.exe -r
Restarts your computer in 30 seconds.
shutdown.exe -l
This one will logoff your computer back to the welcome screen where you will need to login again.
shutdown.exe -s -t 1
Shutsdown your computer in one second. the -t 1 tells it how long to wait. (one second in this case) You can put -t 10 or even -t 1120.
shutdown.exe -s -t 15 -c "Goodbye you idiot"
This is my favorite code. It will shutdown in 15 seconds and have a message in the box saying "Goodbye you idiot"
The -c "bla bla bla" stands for a comment.
Notes:
* to stop the computer from shutting down type shutdown /a into the run box located in the start menu..
* -f will force everything to close immediately without asking to save anything.
on Jan 29, 2010 | Computers & Internet
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
My acer 5750 i7 keeps shutting down
The infected laptops encounter random shutdown problem until some maintenance activity is being performed on the system.
Two important things that you should do to fix a laptop which keeps shutting down are:
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes.
For an instant fix use system utility tool Reginout.
WebRepOverall ratingThis site has no rating(not enough votes)
Dec 12, 2012 | Acer Computers & Internet
1990 dakota engine shutting down randomly
I had a 1988 dodge Dakota ,and it did the same thing. I fould that the o2 sensor was bad. I am a self employed mechanic
Oct 28, 2012 | Dodge Dakota Cars & Trucks
IBM R52 Seemingly Random Shutoff and gaming lag.
If you can increase the drams to maximum in your computer?
Mar 03, 2012 | IBM ThinkPad R52 Notebook
HP pavilion ze4300 will not shut off.
Two things you can do, you can hold down the power button, keeping it held down, should power it off. The other solution is to remove the battery, this should cause the Notebook to power down
Feb 28, 2011 | HP Pavilion ze4300 Notebook
It shuts down about a minute after you start it the acer aspire one
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
Screen turned off and when i pressed shutdown it wont shutdown
Hold the shutdown button for 15 seconds (be sure to count slowly). If this still doesnt help and you ABSOUTELY need to solve this issue, then you can try to risk removing and reinstering the battery pack of your laptop.
I tsounds like your laptop overheated. it should return the normal once it is rebooted.
Jul 02, 2009 | HP Advanced Port Replicator 1.2
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
Jun 11, 2009 | Acer AL2216W LCD Monitor
ASUS P5P800-VM Motherboard Logo
175 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
