Question about Bissell Vacuums
Belt wont stay on Bissell cleanview bagless. Falls off within minutes after fixinging it- brand new belt. How do I fix this?
  • ice456789 Sep 16, 2008
    I have the same problem. I first noticed it when I smelled burning plastic. The belt had slipped off the motor assembly and in the process burned through some of the vacuum housing. If there was something holding the belt on the motor, it's gone now. The belt just sits on the rod until it decides to slip off, usually about every 5 minutes running. Finally the belt broke. There must be some piece that holds the belt on the motor axle, but I don't see where it would have gone on my vacuum.
  • 120 Answers
Make sure the roller turns freely with almost no resistance if not get a new roller.
Posted on Sep 17, 2008
Need a new belt for a bissell lift off revolution turbo
Hi Dale, sorry to hear the belt has broken. Now is a good time to order filters for orders that are $30 or more receive free shipping. Here's a quick link to ordering one.
http://www.bissell.com/parts/?sc=search2&searchtext=3760
Jan 26, 2013 | Bissell Cleanview Helix Deluxe Bagless...
My vacuum brush wont rolling when I use it, so I think when I use it, it seems it doesnt work at all, what can I do to fix this machine, so I dont have to buy the new one? Thanks a lot for the answer..!
the belt that drives the brush may have came off and twisted jamming brush,or could be jammed with a string off carpet edge, you will have to remove cover from bottom of unit and clean debris or replace belt. good luck
Jan 06, 2011 | Bissell 82H1 Cleanview Helix Bagless...
How do i change the belt on my bissell powertrak
Give this a try.
http://www.ehow.com/how_2320063_replace-drive-belt-bissell-cleanview.html
Sep 05, 2010 | Bissell 3594 CleanView PowerTrak Bagless...
New Bissell Cleanview Helix is aking a high
It most likely is a worn drive belt. Here is a link to the belt you need and the manual:
Bissell Cleanview Helix Belt and Manual
Nov 24, 2009 | Vacuums
Makes too much noise {high pitchs] like the motoris spinning the belt to fast.
That noise usually means that the belt is worn or stretched and its slipping on the motor shaft. Replacing the belt is easy to do and you can get the belts for this model here:
http://vacbelts.com/bissell-style-7910121416-belt.htm
Oct 18, 2009 | Bissell 3590 CleanView Bagless Upright...
Bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Jul 07, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Roller wont spin
The bearings in your brush roll are bad. Replace the roller and walla problem solved!
Apr 13, 2009 | Bissell CleanView II Plus Upright Bagless...
Vac quit working
I have a Bissell powerforce bagless 12 ampsthe brush will not turn, motor is working not sure if brush is gone or I need a new belt it shows spots of burns like the brush is jamed
Feb 23, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Roller and belt changing need schematics
How to change the belt on the Bissell Clearview?
Sep 02, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
264 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
