Question about Dishwashers
MyWhirlpool model number DU920PFGG2, serial number FJ3453664 is leaving a white chalky film on my dishes. The rinse cycle sounds like it should be working but it isn't rinsing well. We are also using jet dry but that isn't helping. Any ideas? Thanks
SOURCE: white film on dishes
Experience : 30 years in dish washing as a professional instructing hospitals and restaurants.
It is not necesaasry to cover the heating element as long as sufficient water is present so as to not STARVE the water pump.
Listen to the sound of water serging with the machien running. If it is contant you have enough water if the sound comes and goes then the pump is serging . either lyou have a low water level or CLOGGED strainer in the bottom of the machine (inside).
you might also open the door real fast during the wash and check for water splashing and flows---- you might get wet but this way works .(wear protective eye shields)
water levels can be raised by BENDING the tab on the bottom of the float which controls water level...much like a toilet tank float.
Also finally if soap levels are too high the soap will not rinse off regardless of the amount of "rinse fluid you use.
Visit www.soapman.com
regards
soapman Bruce
Posted on Dec 30, 2007
textonor
  • 130 Answers
SOURCE: Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Posted on Feb 03, 2008
Hard water "filming" is caused primarily by the higher deposit content in hard water clogging up the jets and nozzles. Therefore, there is not the normal pressure for washing or rinsing. This can be eliminated by turning on the dishwasher, while it is empty, and waiting for it to fill and go into it's wash cycle. They open the door and add 3 cups of white vinegar and finish running through the cycle. This will open the nozzles and jets to their full capacity. After that, use a rinse aid for sure.
Posted on Feb 07, 2008
IFIXALL
  • 868 Answers
SOURCE: dishwasher leaves heavy residue
Check your spray arms and look for the holes that water sprays through .Are there any clogged holes.Clean them if you see they are clogged.If not clogged up,your heater is not working ,check for voltage > 120V. If you have 120V. Check water level,it should be just under the heater. PLEASE LEAVE A RATING !!!!!
Posted on Jun 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: chalky film on dishes
check to make sure you are using the correct detergent & amount for your new washer - depending on the hardness of your water.
Clean the air gap.
Your problem could be one of two things. 1) Hard water. Outside of getting a water softener there really isn't much of a cure for that one. If you are unsure if you have hard water or not, simply take a sample to a local fish store and most of them will test it for free, or call your city's water department and ask. 2) Most likely though it is because you are using too much detergent. How often have you said to yourself, gee there's a lasagna pan in there, better fill up the little dispenser AND give it an extra big 'ole squirt just cuz it's really greasy? Try this, place a coffee cup standing upright on the bottom rack of your empty dishwasher. Fill the cup up to the brim with vinegar and run it through a cycle. This should clean out any residue that is in there currently. Then, the next time you do the dishes use HALF the detergent you normally use. See if that helps. Good luck!
Posted on Jan 08, 2009
Glass and cutlery has a chalky white film after washing
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Apr 21, 2011 | Dishwashers
Dishwasher leaves dishes covered with white chalky residue
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 26, 2011 | Whirlpool ADP 8900 Dishwasher
I have a Kitchenaid dishwasher Model KUD101lLWH6 - Serial number FR4205761. I have not changed soap or rinse product since I got the dishwasher but I am getting a white looking film throughout the...
The white film that you are talking about could be two things. First is the quality of your water, having sediments either through the water system or from the water heater because the water that goes into the dishwasher is taken from the hot water supply. Second is the build up of soap residue and even with a rinse product it is not able to remove it. A simple remedy is to due a wash and rinse cycle without dishes and put vinegar in the dishwasher about a cup full (8 oz) and see if that will help. If not I would check the water and going in and out of your water heater. Good Luck
Jan 06, 2011 | KitchenAid Dishwashers
I have an older GE dishwasher Model # GMB921HB119. The machine operates normally till it reaches what I believe is the final rince cycle and stops. The timer continues to advance, reaching the drying cycle...
heatman101
0--0
Dec 26, 2010 | Maytag Dishwasher
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
heatman101
Oct 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Model # GLDA690MBB is only 2 - 2 1/2 years old, and only recently I've noticed a white chalky residue left on everything after it's finished. I 've always used the cheapest detergent and never had a...
heatman101
l'';
Aug 17, 2010 | GE GLDA690MWW / GLDA690MBB Built-in...
Bosch shx33a05uc/14 dishes are milky with white chalky residue. Have cleaned the inside, and checked to make sure the water can exit the spray holes in the circulating parts (top and bottom). Checked...
heatman101
May 11, 2010 | Bosch 24 in. SHX33A05 Stainless Steel...
White film 0n dishes and especially glasses
It is a drain problem, check the drain hose and drain pump.There should be some problem with the drain being blocked that is eventually pushing the dirt water back and front.Thereby leaving detergent and dirt back in the dishwasher.
Provide me the model number and i can help you out with some internal diagrams in case you don't find the drain pump.
Good luck and please do post for further doubts arising on this solution.
Jan 20, 2009 | Dishwashers
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
