Question about Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox dispenser
I have a Maytag Skybox Vending machine. Having problem - push buttons and nothing happens, except they blink. Tried to clean sensor - it worked once but not twice.
Could I get a copy of the manual if possible? My email is rogersblis@aol.com
Thanks alot,
Jim
  • 18 more comments
  • jmreed135 Sep 29, 2008
    same thing one drink will dispense then all the lights will continually blink...can i get the same solution / repair manual...Jmreed
    jmreed135@windstream.net
  • truck46 Oct 05, 2008
    Well, my just started doing a similar thing. I push a button and all that happens is all four of the buttons blink and nothing happens. Have to open door to get a drink. Any suggestions? steve@1946chevy.com
  • rasmith Oct 08, 2008
    Same problem, I have taken the machine apart and verified all the motors work. I'm not sure if it's the card inside the machine or in the rear. If I push a button the motor may or may not work. If it does vend the lights all blink and I have to open the door and close it to get it to reset. Please send help to rasmith@bulletpowerstation.com
  • tanner08 Oct 11, 2008
    I have the same problem
  • Anonymous Oct 12, 2008
    My skybox wont work.
  • bambamsports Oct 13, 2008
    Same problem here. If anyone has suggestion or manual please email me.
    Thanks,
    Brent
    bambamsports@yahoo.com
  • freddy666pam Oct 15, 2008
    I have the same problem with my skybox machine, i push the button, it make a sound but nothing else happen. What can i do?
  • Sharon Endicott
    Sharon Endicott Oct 18, 2008
    Mine ices up even if the temp is not on high
  • 03infantry Oct 21, 2008
    Same prob.... email me with manual or solution please.... 03infantry@gmail.com.
    Thanks
  • edlu21 Oct 22, 2008
    please email me a copy as well. thanks
    edlu21@hotmail.com
  • Anonymous Oct 27, 2008
    same problem...can you send me the manuel too
    chicanalove000@yhaoo.com
  • hamsandwich2 Nov 03, 2008
    Hello I am having the same problem with my skybox. the lights blink but nothing else happens. Any help would be great thanks. Hamsandwich2000@hotmail.com
  • cgarrett216 Nov 09, 2008
    I am having the same problem. Please email me at cgarrett@northparkbc.org. thanks
  • k blake Nov 09, 2008
    I have the same problem and can see that the sensor is corroded. Can you e-mail me a copy of the manual (kandjblake@verizon.net) and does anyone know where parts are still available? Thanks
  • mitz mouse Nov 11, 2008
    cools the drinks but will not dispense any drinks
    sherlovaglio
  • jaredpro2007 Nov 18, 2008
    push buttom. nothing happens but light blinks. How do i fix this?
    my e-,ail is jaredpro2007@yahoo.com
  • Letner123 Dec 09, 2008
    I was stupid enough to buy one off Craigslist and didnt try it out before handing over the money. Wont dispense drinks. Compressor has already been replaced, so now I need this hard to find PCB board?
    THANKS
  • tlan Dec 13, 2008
    when i push the button to get a drink all the lights blink i have cleaned the sensor still the same problem do you have any idea what i can do to fix it thanks
  • saylorhouse Jan 10, 2009
    Skybox will not dispense when you push the buttons. Please help!!!!
  • alexa11 Jul 24, 2010
    I am looking for the hinges and manuel for this. Any one know where I can get parts? underpressure383@hotmail.com. Thanks
Read a post that said to manipulate the sensor a little, but when I found out where the sensor was (it is in the back of the door, behind the panel just to the right of the opening and the flap behind two screws) I found that there was nothing wrong with the sensor at all. The problem was simply that my door flap was not closing completely (and thus not tripping the sensor). It seems that if the door does not close completely that the machine thinks that there is a jam. I held the flap down completely and pushed the button and out came a drink from any button. I cleaned the flap and lubricated it with a little WD40 and BAM, back in business. I could not believe it was something so simple. It took two minutes to fix! Hope your has the same so it can be that simple.
SK
Posted on Jan 04, 2009
  • 59 Answers
REMOVE OLD SWITCH 11001182  . CUT THE 3 WIRES OFF THE LITTLE BOARD ,ONE END WIRE WITH X WRITTEN DO NOT USE. THAT SHOULD LEAVE CENTER WIRE AND 1 END WIRE. GET A STANDARD WINDOW ALARM SENSER FROM RADIO SHACK .MAKE SURE IT CLOSES WHEN MAGNETS ARE TOGETHER. SILICONE THE ONE THAT WIRES CONNECT TO SOLID EDGE OF DOOR FRAME ,OTHER TO END OF MOVING DOOR. WHEN SODA HITS DOOR MAGNET OPENS, THEN WHEN SODA IS REMOVED IT CLOSES ENDING CYCLE. IF YOU ARE NOT SURE OF WIRES JUST CONNECT 2 END WIRES ON ONE SIDE ,NEVER THE 2 OPPOSITE ENDS.
Posted on Apr 20, 2010
  • airdoctorz Apr 20, 2010
    WHEN YOU USE ALARM MAGNETS THEY MAY NEED TO BE 1 INCH APART. SILICONE TO UPPER RIGHT CORNER.
  • 3 Answers
Problem may be the PCB board (w/Sensor) for the Flipper Door. It has a tendency to become corroded due to condensation that can build up by the door. Maytag replacement part number is 11001182. Part is hard to find. I was able to get one after much searching. Within 3 days it was out of stock again.
To combat the condensation (and ICE build up on the rear main board), turn the fridge down to half and keep the front lights off as much as possible. You may want to play with the settings a little depending on the area of the country you are in (dry Arizona as opposed to wet Washington State) but you shouldn't have to go below half.
Even though the lights are flouresent, they still throw off a lot of heat which causes condensation. The fridge runs longer to combat the heat so the added moisture freezes in the back (where the cooling elements are) and the condensation builds up in the front where the sensor and heat source is. It's cool enough in front to hinder evaporation and because the fridge runs longer you don't get that defrost period (if you will) in the back that regular frost free refrigerators or freezers have, thus the ice build up. Hope this helps.
Posted on Nov 13, 2008
  • k blake Nov 13, 2008
    Sorry, forgot to add this will greatly reduce condensation but may not get rid of it all. The front door is not to well insulated which probably contributes to the heat bleed from the lamps.
I found that if I don't turn the temp all the way to high, the ice doesn't form and the buttons work properly. However, when you do have to defrost it, have lots of dry rags handy--water goes everywhere.
  • Sharon Endicott
    Sharon Endicott Oct 17, 2009
    I find that if ice builts up the buttons do not work properly. Love it when it works.
  • 3 Answers
I also have one of these vending machines. The problem Maytag had with these and the reason why they are discontinued is that it was not made with an automatic defroster. SO, ice litterally builds up on the entire motor in the back and then the buttons do not work. Here is an easy test. Unplug the machine for 24 hours and if there is ice on the motor it will melt off(to where I dont know!!). Try the buttons again and see if they work. Mine did. They also had to come out and replace one of the pieces inside because the ice broke it! Mine by the way does not work anymore because the other problem they have had with these is that the compressor goes bad!! Once THAT happens, its more expensive to fix than it's worth! Good luck! Maytag SUCKS!!!
i have the same problem, i push the bottom and nothing comes down. all i get is the lights blinking, can you help, i'm also looking for dallas cowboy panels. thanks,email address is matthewgorn@yahoo.com
Posted on Sep 22, 2008
  • 770 Answers
Check your email
  • Jeffrey Mclaurin Nov 05, 2011
    can i get a copy please? my email is jeffrey6719@gmail.com. and also is the a website to buy parts for the dispencer. i need the round motor and the little plastic piece that kinda resembles a check mark or v. that push up to stop more than one drink to dispence on 2,3
The vending on my maytag skybox stopped working
What do the led's do when you try to dispense a product?
May 05, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
SkyBox second button will not dispense
If nothing happens, the switch behind the button must be broken, or something on the PCB that the button is mounted to is broken. But if lights blink, then the button is ok and the problem is with the motor or some sensor. I have a troubleshooting guide for the dispensing system (better than Maytag ever published), as I was directly involved in the design of this product. This does not cover the refridgeration system, as that was provided by our Chinese manufacturer. Please email me at: garymyers@insight.rr.com if anyone wants this guide.
Jan 02, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox - Dispense Problem/Lights Flashing
I returned the machine to where I bought it. It not only didn't dispense, it also didn't refrigerate. sorry I don't have an answer for you.
Sep 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
CAN A SKYBOX 'MAYTAG' BE PERMENENTLY INSTALLED OUTSIDE
The Maytag SkyBox is not a commercial vending machine. It is designed for INDOOR use only. The possibility of electric shock is likely from a unit that has gotten wet. In addition, the electronics are not designed to withstand the outdoor elements.
Aug 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
3/4 buttons work
mine did the same thing. apparently, if the internal unit gets too cold, it freezes operation in some of the buttons. try turning up the temp to let it thaw, then try the button again. the downside is that when you turn down the temp again, you are likely going to face the same problem.
Jun 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Cannot get soda to dispense
Sounds like the child lock is turned on. Have you checked that?
Dec 27, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Beer won't dispense, last one furthest to the right.
Have you checked the child-lock buttons?  They are located on the right side of the machine and are accessible only when the door is opened.
Sep 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
2,236 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
