Question about Haier HTP18GAA Top Freezer Refrigerator
My freezer is working but my frige is not cooling
I have a top freezer refrigerator and the bottom frige is not cooling but the freezer works fine. there was ice built and i clean that up but the bottom frige is still not cooling . the model number ishte21waaww and the serial number is 01909051557090007404
  • Anonymous Mar 20, 2014
    The freezer has icicles forming and frost. Te frige is freeing on the little white plastis on the top middle back
    Champion:
  • 210 Answers
Wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Posted on Sep 15, 2008
  • did you remove the freezer panel and defrost and remove all the ice on evap. coil? the air damper could be closed, try feeling for air coming into ref. area.
I have a ge frige that the freezer works but frige is warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
Our freezer seems to be working fine, however, the fridge part doesn't seem to be cool at all
all you have to do is defrost the frige the freezer sometimes will freeze up with ice in the back of freezer where the air flows into frige
Mar 13, 2010 | Haier HTE18WAA Top Freezer Refrigerator
I have a hotpoint ctx16bazbrwh. Recently the frige part has stopped cooling but the freezer is still working fine what can it be, what should i do? it is a top and bottom, freezer on top.
ice blockage occured. check the damper in back of fridge to check air flow. usually when the drain is clogged it acumulates water causing it to freeze on the damper causing blockage
Feb 05, 2010 | Refrigerators
Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
Refrigerator side not working
The freezer is workig fine but refrigerator side is not cooling.
Jun 10, 2008 | Whirlpool GS6NBEXR Side by Side...
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Side by side freezer
Check that the freezer circulating fan is running. The frige section may have dampers or vents (lets the freezer air cool the refer section) that are open too much. Usually the bottom area in the frige has a control lever to meter how much cold air gets to that section (lots for meat, little for fruits, etc.). Check the owners manual for operation of those vent dampers.
Oct 22, 2006 | Maytag 60ADiW Side by Side Refrigerator
Haier HTP18GAA Top Freezer Refrigerator Logo
342 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
