Question about Haier Heating & Cooling
The power plug keeps tripping. when i press the button on the plug. it just trips.
    Scholar:
  • 141 Answers
Either there is something wrong with the unit or you have something else plugged into the same circuit. Air Conditioning units draw a lot of power and will trip a breaker if there is a moderate load on the same circuit. Try plugging it in to an outlet that you know doesn't have anything else on it. The other thing you can do is see what else turns off when the breaker trips, that will tell you what else is on the circuit.
Posted on Sep 15, 2008
How to reset oil maintenance switch
I believe it might be in manual also. Here is instructions.
Switch the display to the trip meter "A"
Turn the "POWER"switch off.
(If you have push button start)
While pressing the trip meter reset button turn the "POWER" switch to ON mode (press power button 2 times, foot off the brake).
Continue to press and hold the button until the trip meter displays "000000"and the multi-information display indicates that the reset is complete. or you here a beep.
May 17, 2014 | 2012 Lexus IS 250
How to disable Prius back up beep
This is a pretty easy fix.
1. Keep you foot on the break and turn the car on.
2. Press the odometer/trip button until your dash displays the odometer mileage.
3. Turn the car off and while keeping your foot on the break, restart the car by pressing the on button.
4. Immediately press and hold down the Odometer/trip button for at least 10 seconds.
5. While still holding down the Odometer/trip button put the car in reverse. You will hear the reverse beeping. Then push the park button.
6. You can now release the Odometer/trip button and if you keep pushing the button you can toggle the beep to come on or turn off by looking on your dash. It should say "b-on" or "b-off".
7. Toggle it to the "b-off" setting and put your car in reverse and that annoying beep should be turned off.
Jan 14, 2014 | 2008 Toyota Prius
Where is the trip meter reset button on a Lexus ES350
Hi there:
  • Turn the "Engine Start Stop" switch OFF with the trip meter A reading shown.
  • While pressing the trip meter reset button, set the "Engine Start Stop" switch to the Ignition ON mode. Continue to press and hold the button until the trip meter displays 000000.
  • Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using FixYa, have a nice day.
    Aug 21, 2012 | Lexus ES 350 Cars & Trucks
    Prius start up beeps
  • Power on the car to IG-ON or READY. IG-ON will do for this purpose.
  • Using the Trip/ODO button, set the Trip/ODO display to ODO - not Trip A or Trip B
  • Power off the car.
  • Now power the car to READY (brake on). This is required so that step 6 works correctly.
  • Immediately, within 6 seconds of powering on, press and hold the Trip/ODO button for 20 seconds or more. Do not release, just hold it for 20 seconds.
  • Then WHILE STILL HOLDING ODO button, shift the "gear" selector from Park to R, then press the Park button. Now release the Trip/ODO button.
  • If the last step was successful, b on or b off should be displayed in the location where the Trip Odometer or Odometer is normally displayed. b on is beep on, and b off is beep off.
  • Press the Trip/ODO button to toggle the mode to the one you want.
  • Now power the car off to exit the toggle mode.
  • Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if b off was selected, and should be audible if b on was selected.
  • Jun 06, 2012 | 2004 Toyota Prius
    How to reset timing belt warning light after 150,000 km on toyota hiace 2kd-ftv engine
    if it has a digital odo/ press trip knob until odo is displayed/ press and hold , turn ignition , hold for 4 secounds , release and press again, number 10 will be displayed, keep pressing until 20 comes up, press until odo reading is displayed again, turn ignition off , turn on again , notice the t belt lamp turn off in appros 5 secounds / if not able to reset try this again
    Apr 02, 2011 | 2007 Toyota 4Runner
    How do you turn off the "Car needs Oil Change"
    1. Make sure the trip odometer is NOT on 'Trip A' or 'Trip B' (ie: just the normal ODO). With the ignition off, press and hold the reset button. Press the 'Start' button twice without pressing the brake, but while holding the reset button. The dash will let you know its resetting, just keep holding the button until it is done.
    2. Make sure the Trip/Odometer is set to "trip A". With ignition off press and hold the reset button. While pressing the reset button, press the start/ignition button twice to turn ignition on. Keep watching the trip/odometer display to flash the lines (-----) until you see it flash the zeros (00000) then it
    Feb 22, 2011 | 2009 Lexus LS 460
    How do I remove the "needs Maintainance " code. Is the interlink sunvisor a plug and play accessorie? Is the compas mirror also a plug & play accesorie? Are there any reputable salvage lots that...
    The maintenance light goes away like this:
    1. Turn the ignition key in 'I'-position
    2.Press the trip odometer reset button (make sure that it is showing T1. Make note on the mileage).
    3. While keeping the reset pressed down, turn the ignition key to 'II'-position.
    4. Wait until the service light (or the yellow triangel) has blinked three times or the trip mileage has returned to show the previous mileage (not reset to 0.0)
    5. Release the trip reset button.
    5. Release
    Jan 13, 2010 | 2007 Volvo V70
    How do you clear the service light on a S60 T5 2003. Please can you help.
    Ensure all doors are closed.Turn ignition key to position 1.Press and hold reset button on a dashboard left hand side down/instrument panel/.Immediately turn ign.key to position 2.Keep reset button depresed until trip meter is reset to 0. NOTE:IF trip meter has already been reset.Hold reset button for 10-14 secondsuntil previous trip meter reading is shown.Press and hold reset button until trip meter is reset to 0 ;;;; Release a button within 4 secondsThere will be an audible signal When reset complete.
    Nov 28, 2009 | Volvo S60 Cars & Trucks
    Air conditioner breaker on plug keeps tripping
    The instruction manual says:
    If the safety device incorporated in the plug trips and cuts off the power supply, check that the power cable and plug are not damaged. If the power cable is undamaged, to restore operation press the RESET button.   To verify the correct operation of the plug, press the TEST button periodically and make sure the appliance disconnects.  If this is not the case, contact the service center. To restore operation, press the RESET button.
    Customer Service: 800-322-3848  US Customer Service: 888-335-6644  Canada
    Hope this helps!
    Jun 08, 2008 | GE Heating & Cooling
    Power tripping
    First off, lets make sure its not the wiring in your house. disconnect the dishwasher and plug in something else and see if it trips the fuse. also what amps is the breaker rated at?
    Nov 02, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
    Heating & Cooling Logo
    446 people viewed this question
    Top Haier Heating & Cooling Experts
    Tom Chichester
    Matt
    Matt
    Level 1 Expert
    Edd
    Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
