Question about Canon Pixma MP500 All-In-One InkJet Printer
LCD Screen The LCD screen on my printer has gone completely black. Is there anything that I can do, like maybe changing a bulb or something?
My screen is completely black but sumtimes it lights up for a sec. dunno wut to do
Posted on Sep 23, 2008
Camera screen will not light up
The LCD screen maybe faulty.
Take your camera to an Olympus camera repairer for repair.
Apr 06, 2013 | Olympus FE Cameras
My sony camera dosn't work and i can't see anything just black screen
of course you need to check first, is it completely black screen. could be that its not even turning on.lucky if lets say beep feature was set to on . check if you press any buttons, is there any beeping sound. try to even press the playback and check if any icons will appear.or press the lcd button repeatedly and check if something will happen . if not , do power reset. take out the battery and hold the power button for 30sec. its like refreshing the memory of camera.. if still same thing. try changing batteries. camera also turns on by pressing playback button. if all ts fails, camera needs service. could be something wrong with its sensor.
Oct 24, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
How do i replace a bulb or lcd screen on akai s3000
If you can see something, but very dim, it will be the backlight. search well known auction site for replacement with plug in lead, will require no more than a philips screwdriver to repair. Instructions with part
May 18, 2012 | Televison & Video
Nikon L110, LCD does not display anything some cracks are showing on Lcd, though glass is O.K
when the lcd screen does not display well, it maybe something wrong with the screen such as the screen leakage,black spot,or edge chipping.there is 2links for you,wish it can do a little favor to you if you want a clear and clean lcd screen.
http://skiliwah.cn/
http://www.digitalcamera-parts.net/
MSN:e-8090team@hotmail.com
cindy(skiliwah)
Aug 17, 2011 | Nikon Coolpix L110 Digital Camera
Black screen
Usually when you see a reddish hue then black.....is indicative of an inverter or backlight failure. Hold the laptop up after it is started and look from the bottom toward the top. Try to shine a flasklight at the bottom of the screen upwards...see if you can see the windows startup screen or anything that gives an indication that the laptop is running and booted to where you can faintly see something on the screen. If you can barely make out an image, then 9 times out of 10 you need another inverter. There are rare occasions that a backlight bulb will fail, but this is rare and most backlight bulb failures are from shock damage. The inverter can be changed by simply removing the screen bezel, unplugging the inverter and changing it. If the bulb has been broken or burned out, it is more cost efficient to simply change out the lcd panel. The bulb sits in a channel under the lcd panels inside the aluminum framework. The panel has to be disassembled to remove it.
May 23, 2010 | Toshiba Satellite Notebook l505dls5005
Screen is black..will not display anything. Any
You provided very little information, so I'll try to answer:
I assume you turned on the comptuer and it seems to be working-you didn't say.
I assume it used to display something-you didn't say.
Hook it up to an external monitor. Can you see something? If so, one of two things are wrong: Your LCD screen has gone bad OR you need to hit the Fn/Special function key combo that moves the display from your LCD to an external monitor.
If none of these solves the problem, then your video card has gone south on you.
Jan 23, 2010 | Toshiba Computers & Internet
TURNING ON BUT NO SCREEN DISPLAY
Did you try to connect to external monitor see if you get picture?
If does, You need to look very close the laptop LCD if you have seen any shadow pictures? if does your Inverter or Bulb is Gone. If no pictures on external, Your graphic card is done.
JMC
Aug 18, 2009 | Acer Aspire One PC Notebook
Screen Black can barely see images when boot up
well seems like the lcd has lost or the video card has an issue easy way to find out is to hook it up to a monitor and if the pitcure comes out fine then its your lcd screen and if it appears the same then its your video card.
Feb 09, 2009 | HP Pavilion dv1000 Notebook
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
Canon Pixma MP500 All-In-One InkJet Printer Logo
121 people viewed this question
old marine
old marine
