Question about Sanyo VPC-HD1 HDV Digital Camcorder
VPC-HD1 Hey - I have the service Manual - shows you how to take it apart and put back together. Have the same blank screen issue but menu works perfectly. I am about to dive in and take it apart myself - will have to figure out how to clean this iris. Let me know if you want me to send you pdf.
  • 3 more comments
  • neel_rani Nov 10, 2008
    I have the exact same problem. can you please send service manual copy to neel_rani@yahoo.com . thanks :-)
  • dilge Feb 06, 2009
    I have the same problem. Is it OK to send service manual copy to Paul.dilger@tiscali.co.uk Hope to hear from you . Thanks.
  • lcspoon Feb 22, 2009
    I have the same problem. Please send me a copy to lcspoon@hotmail.com . Thank you.
  • emiller19 Mar 08, 2009
    I have the same problem... please e-mail me the manual to emiller19@aol.com
    also, were you able to fix it? if so, what was the real fix...
    thanks
    ed
  • bpm166 Apr 20, 2009
    Did anyone recieve that 'Service Manual' ?
I might as well join the crowd! Hope SONY figures this problem out, seems to be rampant. If you could send me the pdf copy as well I would greatly appreciate it!
Thanks! tslake2004@yahoo.com
Posted on Nov 03, 2011
Hi
would be very gratefull for if anyone can send me the manual PLZZZZ
diaboardic@live.com
Posted on Feb 16, 2010
Nov 10, 2008- I have the exact same problem. can you please send service manual copy to m.nicotra57@yahoo.it . thanks :-)- i
Posted on Nov 16, 2009
Yes I am interested. Please send me a copy to naipadtu@yahoo.co.uk Thank you.
Posted on Sep 30, 2008
  • sushilsareen Sep 13, 2011
    I have same blank screen problem with mu Sanyo VPC-HD1. Please send me maunal at my mail id sushilsareen@yahoo.com.
How do i clean the iris blades?
This is for Sanyo VPC-HD1, VPC-HD1A black screen problem how to clean auto iris unit.First you have take apart camera : remove 4 screws from right side (in battery compartment) 2 screws from bottom, 2 screws from top (there are different short one is from rear) and last screw from front, now pull left cabinet from top and take appart.Be carefull !!! there is flash capacitor you need to discharge it before doing anything else.You can discharge with  1Kom 5watt resistor . After that remove 1 screw holding speaker, disconnect and remove speaker.Now pull power board PW-1 there is a screw holding lense ring remove that screw, disconnect 2 connectors from lense assy (from ccd just pull, from lense unlock and pull flat cable now you can remove lens assy. Next remove 3 small screws holding heat sink (rear of lens assy) after that remove spacer (black tape from top of lense and another small tape at rear top of lense. Now you can see 7 white screws and 1 black screw remove all of them.Black screw holding iris unit.Now carefully lift zoom motor focus motor 2 sensors nd filter assy and iris unit they came out all together.Next thing main thing you have to open iris unit it is easy to do with sharp blade on the edge of iris unit you will find 2 locks holding  metall casing of iris unit put blade between metal and plastic case and pry to remove metall case. Now you will find iris 2 blades there are different you need to remember wich is wich.Now carefully remove both blades (they might stick to each other because of grease) and place them into isoprophyl alcohol after that put them on to napkin fold napkin so blades are inside and dry them you also need to clean iris unit where blades are going from grease and also clean zoom motor and focus motor shafts to remove grease. Now put everything back together and i hope you can do that. Good luck.
Aug 17, 2008 | Sanyo VPC-HD1 HDV Digital Camcorder
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Apr 25, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Sanyo VPC-HD1
Iris is not the cause of black screen.First confirm that shutter is opening as soon as you switch on camera.If shutter is not opened and you can't see live view on screen except black screen,then certainly there is problem with shutter assambly.
If shutter opens and you see black screen then there is problem with CCD.
Mar 10, 2008 | Cameras
Sanyo XACTI HD1 Camera-No Pictures / Videos captured.
I have intermittent problems of this type too. Occasionally I get a blank screen in the display mode.
Does the red light on the back of your camera flash while the screen is dark? Mine does.
It is beginning to bug me a lot. It may be because I got my camera wet in the past (and hence I have broken my camera), but I doubt that would result in a partial failure.
I think that the Xacti HD1/HD2 has issues a bit like a blue screen of death on an old Windows computer when faced with storage problems.
I.e. it works but crashes sometimes when it cannot store to its storage medium.
These things work for me
1) Turning the power on and off via the button underneath the screen.
2) Removing and re-inserting the SD card.
3) Turning the power on and off by removing the battery.
4) Using a different (and faster?) SD card.
I am still using my HD2, but I am finding that I must attempt solutions 1-3 about once a day.
It could be because the card I have been using recently is not fast enough. The HD2 accepts both SD and SDHC cards. My SDHC card (which is newer) seems to result in fewer problems, either because the SDHC format is more suited to the Xacti HD2 or becaues the SDHC card I have is faster that then SD card I have. I suspect problems with the speed of the card. I am using cheap SD cards.
Dec 07, 2007 | Sanyo Xacti HD1 Memory Card Camcorder
Sanyo VPC-603 Digital Camera
Read the Manual- this may be more comprehensive on the software disk in a PDF file
Jun 03, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Blank Screen!
Bring it back for repair.
Feb 04, 2007 | Samsung SCH-a670
Open Questions:
Sanyo VPC-HD1 HDV Digital Camcorder Logo
172 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
