Question about Maytag Washing Machines
I have a maytag Modle #sav3710aww sn 13663589ev and the hose leaks that emptys the tub and i can't get the front of the washer off to fix it or see if i can fix it. How do you get the front off
    Sergeant:
  • 409 Answers
you'll have to take off the top panel first and then the front.
go to www.whirlpooparts.ca to see the exploded view & parts list.
Posted on Sep 15, 2008
Leaking maytag neptune washer
The pump and its various hoses are easily accessable through the back panel. The boot can collect coins which can block the pump. Squeeze the boot and empty it of all coins. Coins can ruin the impellers on the pump. A new pump costs $100 on line. The drain hose can be plugged by dimes and pennies. Good luck.
May 28, 2014 | Maytag Neptune MAH5500B Front Load Washer
My Maytag washer was purchased in October 2003. Model No.: SAV3655AWW Problem: My washer is leaking from underneath. The hoses connected on the outside are very tight. Can this easily be repaired?
this coild be easy fix ... remove front cabinet and verify internal hoses or pump... if coming down bottom of tub the its tub seal and bearing and u arent gonna be happy on price very extensive repair and requires a specialty tools...very expensive usually around $300.00 parts and labor
Feb 03, 2011 | Maytag Washing Machines
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Water leak dripping down left front corner
It could be that your washer is filling to much. When you have the front off, take a look at the pressure hose going to the pressure value switch. The water might be filling to high and as it agitate it is leaking from the side. Tof fix this problem you can take the hose off the outer tub and clean the end of the hose with a q-tip and rubbing alcohol. Or try this fix take the front off and check to see if there is a hole in the tub. They make a red apoxy glue that will cover that hole, if it is not to big.
Nov 24, 2009 | Maytag Washing Machines
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer machine wont rinse or open door
did it drain after wash? there is a green pull cord hidden at front of detergent compartment to open door. if it did not drain but pump tried, then clean out hose to pump in rear of unit. remove rubber hose from tub at pump and look for obstructions.
water will come out even if tub empty
Jul 05, 2009 | Maytag Neptune MAH7500WH Front Load Washer
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Leaks
Possible the leak comes from under the tub. Remove the wall plug & take off the rear panel. Check to see if the hose from the under the tub is secure, it could be the grip clip below the hose has come off. This is where it connects to the pump section. You need a grip plier or something to get it back on securely. If this is not the case take a good look to see where the leak comes from.
Next is the door gasket, maybe a tear.
Nov 25, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
