I just bought a belkin wireless router. it is a wireless G MIMO Router. i have set it up, but the number i have to type in on the address bar, it comes up 'nothing to display' i have no idea what else i can type in so i can get my router working? please help asap
    Sergeant:
  • 300 Answers
Gunja
Rank:i just bought a belkin - wizard_s.gif Wiz
Rating: 85%, 88 votes hi,
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
2.The settings to Wireless section of Router appear.Click Channel and SSID.
3.Changing the Wireless Network Name (SSID)
To identify your wireless network, a name called the SSID is used. The SSID is your network name. The default network name of the Router is Belkin N1 Wireless followed by six digits that are unique to your Router. Your network name will look something like Belkin_N1_Wireless_123456.
You can change this to anything you choose, or you can leave it unchanged. Keep in mind, if you decide to change your wireless network name, and there are other wireless networks operating in your area, your network name needs to be different from other wireless networks that may be operating in your area. To change the SSID, type in the SSID that you want to use in the SSID field and click Apply Changes.
The change is immediate. If you make a change to the SSID, your wireless-equipped computers may also need to be reconfigured to connect to your new network name. Refer to the documentation of your wireless network adapter for information on making this change.
4.Changing the Wireless Channel
There are a number of operating channels from which you can choose—in the United States, there are 11 and in the United Kingdom (and most of Europe), there are 13.
In a small number of other countries, there are other channel requirements. Your Router is configured to operate on the proper channels for the country in which you reside. The channel can be changed if needed. If there are other wireless networks operating in your area, your network should be set to operate on a channel that is different than the other wireless networks.
Select channel from Wireless Channel drop-down menu. Click Apply Changes.
5.Using the Wireless Mode Switch
This switch allows you to set the Router’s wireless modes. There are several modes. Note: Some modes may require firmware updates to be enabled.
1) 802.11g only
Setting the Router to this mode will allow only 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
2) 802.11g & 802.11b
Setting the Router to this mode will let 802.11g- and 802.11b-compliant devices to join the network.
3) 802.11n & 802.11g
Setting the Router to this mode will allow N1/draft 802.11n- and 802.11g-compliant devices to join the network, keeping out any slower 802.11b devices.
4) 802.11n only
Setting the Router to this mode will allow only N1/draft 802.11n-compliant devices to join the network, keeping out 802.11g and 802.11b devices.
5) Off
This mode will turn OFF the Router’s access point, so no wireless devices can join the network. Turning off the wireless function of your Router is a great way to secure your network when you are away from home for a long period of time, or don’t want to use the wireless feature of the Router at a certain time.
Select wireless mode from Wireless Mode drop-down menu. Click Apply Changes.
6. Using the Broadcast SSID Feature
Note: This advanced feature should be employed by advanced users only. For security, you can choose not to broadcast your network’s SSID. Doing so will keep your network name hidden from computers that are scanning for the presence of wireless networks. To turn off the broadcast of the SSID, remove the check mark from the box next to Broadcast SSID, and then click Apply Changes.
The change is immediate. Each computer now needs to be set to connect to your specific SSID; an SSID of ANY will no longer be accepted. Refer to the documentation of your wireless network adapter for information on making this change
sahil101
Rank:nonexpert_s.gif Apprentice
Rating: 92%, 6 votes open the the console page of the wireless router by typing this ip address on the address bar in the internet explorer.
192.168.1.1
it will open the console page of the router.on the left hand side
u will see an option which says wireless settings.click on
wireless settings.then u need to look for the option which says
wpa security passphrase,just put the passphrase there n
click on apply,ur wireless connx will be secured. Selah :-)
Posted on Sep 15, 2008
I lost the cd to install Belkin D36094, how can I download, and install have the password.
Most routers can be setup by typing their IP Address in the address bar of your browser. So long as your router is connected to your modem and your computer is connected to your router that is.
Typing
192.168.2.1
into the address bar could get you to the login screen of your router. Then you would just have to enter the user name and password. You might even be able to access a wizard from there to help you set up your router.If that doesn't work you could try 192.168.0.1, 192.168.1.0 etc.
Oct 15, 2013 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to set up a static ip address on a dvr
To access Belkin's web based setup page type 192.168.2.1 on the address bar of the browser.
And if you can follow this web link to setup a static Ip for your DVR , in case if you need further help you can contact me directly ..
http://www.corenetworkz.com/2009/07/setup-belkin-wireless-n-router-by.html
Mar 31, 2012 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can not access the security set up to enable WPA
In order to change or to the wireless security page of your Belkin MIMO wireless router , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page .
3. In the left hand side, under the heading wireless click on Security
4. It will ask for a password to login, leave the password as blank and click on Submit, then you will be find the wireless security page where you can change or check your password
Good Luck!
Thanks in Advance!
With Regards,
Prema
Dec 31, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot go to my router's network configuration page to find my IP Address top play Xbox Live. How do you access this on a Belkin Wireless G Plus MIMO Router?
type 192.168.2.1 in the address bar of your browser...
it will open the configuration page...
click here for screenshots...
if u have any issues comment back i will be online for next 2 hours...
Nov 29, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Bought an Belkin wireless g plus mimo router at
You maybe able to reset the router to the factory default by powering up the router, press and hold the RESET button at the back of the router for 7 secs..
Then open a browser and type in the IP configuration address to reconfigure the router.
Sep 30, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I'm trying to set up a new laptop to my belkin router
When you first setup a wireless router you need to connect the wireless router to the computer with a LAN cable.
Then you open a browser such as Microsoft Internet Explorer and on the address bar you type the IP configuration address of the wireless router eg. for Belkin wireless router it is http://192.168.2.1
Enter the default login name and password.
You should change the password and you should setup WAP or WAP2 encryption (WAP2 is the strongest encryption) and change the SSID and turn off SSID broadcast.
For further wireless protection enable MAC address filtering. The MAC address of the wireless card is entered in the router MAC address filter table, which allows only the wireless card with this MAC address to connect to the router.
The wireless card on the computer needs to be configured with the wireless router's settings. The LAN cable can be removed and the computer communicates wirelessly with the router.
Sep 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to know how to get into my belkin wireless router so i can open my nat on xbox live
Open up a browser window and in the address bar type 10.0.0.2
That will get you into the control page for your router and you can then access all of the settings.
Jul 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Limewire connection
you need to find your router address from your manual (eg. 192.167.0.1). Then type this number in Internet Explorer address bar. If you did all ok at this point you should be opening browser control panel in Internet Explorer. Go to firewall page. Set Limewire software (you may need to use full path eg. C:\program files\limewire\) as an exception in ur firewall.
cheers
Feb 22, 2008 | Belkin (F5D72304F5D7000) Router
Security of wireless network
You can directly connect your computer to the router thorugh the routers "internet" port and then re-run setup. OR you can type the IP address of the router into your address bar (the default is tipically 192.168.1.1 or 192.168.0.1) and then enter the router username and password (I believe the Belkin default is username:"Admin" password:"Password") in the admin control planel look for a "wireless security" tab. You can then define your wirelss security settings there. Just remember to configre the same settings on all devices that will connect to the router.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Problems setting up Belkin wireless G+ mimo modem router/usb network adapter
It sounds like the router address is wrong or you are not connected to the network.. Guessing you are using Windows XP or Vista. Go to the DOS prompt (http://www.computerhope.com/issues/chdos.htm) then type ipconfig. This will bring up details on your network (see example below).
IPv4 Address. . . . . . . . . . . : 192.168.0.4
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
You should see default gateway address which is the address of your router ie 192.168.2.1 in your example. If this is not shown you have not connected to your router properly. If it shows a different address use the address shown to try and access your router. HTH
Nov 14, 2007 | Computers & Internet
Computers & Internet Logo
260 people viewed this question
David Payne
David Payne
