Toshiba television, rear projection, HDTV. - Model #: 50H13 - Serial #: 15703904 - Chassis #: TAC 0360 Blue horizontal arcing line about 1/3 from bottom of screen, a few inches thick. Text displayed a second time, in blue, just above original.
  • mandkbraddoc Sep 21, 2008
    I disconnected the power cord (power point?) for 1 hour, no change. Still lower third of screen with arcing, rainbow-like, blue lines. Most images and text superimposed in blue above original location.
  • mandkbraddoc Sep 27, 2008
    leekiller, great call but didn't get it. wasn't aware of that adjustment but unfortunately unable to lower the blue on most of the positions. down a bit but not enough to make a difference. in fact the blue will go down to a point and then start back up, only '4' centered and the lower three never really get close. red adjusts like gold. I'm hoping there's just a failed plug-and-play module that's failing.
    Genius:
  • 1,268 Answers
It sounds like an internal electronic component is faulty. More likely a burned capacitor and resistor. Try taking off the TV chassis and look for any burned components inside. Replacing those could fix the issue. It seems like the convergence IC needs to be replaced. It would be better if you call a pro TV tech to carefully diagnose the TV and possibly replace those faulty electronics components. If you have a knowledge on basic electronic troubleshooting like soldering and ohm testing, I guess you can give it a go.
Posted on Sep 27, 2008
  • 70 Answers
This is a convergence problem not a reset problem. go into the video menu and look for manual convergence. you could try auto convergence if your tv has it but i think you will have to go in and manually do it. just line the colours insync with the white bars and this will clean up the colours on your entire screen let me know if this doesnt work but im pretty confidant it will
Posted on Sep 21, 2008
    Master:
  • 505 Answers
Ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Posted on Sep 15, 2008
Toshiba 50H13 blurry picture with white line on right side
replace all the surface mounted electrolytic capacitors on the hyper module. also called the scan converter module. this is a common trouble. what a nasty job. good luck.
Jun 23, 2009 | Toshiba 50H13 50" Rear Projection...
Blue screen
you are not getting a signal which means there is a problem with the tuner not working.
Dec 25, 2008 | Toshiba 46H84 46" Rear Projection...
Red & Blue lines on screen
stk392-110 i think mine was made in 2002 and i also had to replace mine
Oct 26, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50h13 image trembling
something is not in tolerance in the deflection circuits if it is an up and down tremble its vertical deflection related and if its shakey from side to side its horizontal deflection. You will most likely need a skilled tech for this type of repair.
Apr 06, 2008 | Toshiba 50H13 50" Rear Projection...
57H81Toshiba Blue Line not straight
You have a bad convergence output IC in the blue vertical circuit. On the bottom side of the chassis you will see a " V " printed by the heat sink. You will need to unsolder the heat sink and the 20 pins on the IC to remove it. Replace with STK 392-180 (sanyo) if possible or STK 392-150. Looking from the rear the heat sinks are big aluminum finned rectangles. There are 2 heat sinks one marked H and one Marked V. Even though you have a horizontal line your problem is in the vertical IC. Be sure to use a liberal dose of heat sink compound.
Mar 21, 2008 | Toshiba 57H81 57" Rear Projection...
Johnnyhotrodcamaro@yahoo.com
Mit has screens that are second to none, if you can't find an official Tosh one. It might need to be cut to size, but no biggie -
Mr Bob
Jan 11, 2008 | Toshiba 55H70 55" Rear Projection...
Does not power on
You can get a service manual by going to this link and entering your model number. http://www.servicemanuals.net/
You should check the horizontal output transistor and low voltage regulators first. Unless you have some experience in basic troubleshooting, you should be warned that you can still get shocked even after the television is unplugged.
Jan 05, 2008 | Toshiba 50H13 50" Rear Projection...
Toshiba 50h13 hyperboard
http://www.hdtvoice.com/voice/showpost.php?p=122387&postcount=7
Oct 16, 2007 | Toshiba 50H13 50" Rear Projection...
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Blue will not Converge
This is the typical convergence problem. There are two IC's that need to be replaced. They are soldered into the printed circuit board. If you have no soldering skills, and are in the US, you can take the model number and go to http://www.ptscorp.com, as they will rebuild or sell you a refurbished board . There is a phone number listed at the site if you need help getting the pricing. Good Luck
Mar 29, 2007 | Toshiba 42HDX82 42" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
