Question about Casio Cameras
Casio EXILIM EX-Z850 Digital Camera The lens does not close.
  • 1 more comment
  • Sokowek Sep 16, 2008
    removing and putting back the camera battery doesn't solve the problem (which occured while
    doing a photo).
    Cleaning did not help. It looks as this is some
    major technical problem. The camera worked well
    for the last year and half till last Saturday when after doing a few photos the lens did not close and retreat.
    Point number 7. fixed the problem. There was a uneven space between lenses which after a gentle tap locked in back into the right position.
    Thanks,
    Eva
  • 4,472 Answers
It is a stuck lens if you don't feel fully confident in your ability to take the camera apart it is a job for a professional I can help you locate the nearest authorized service center you just need to go to
http://www.casio.com/support/authorizedservice/
If you have a moment please accept and rate the solution accordingly, if you need any other assistance please let me know.
Thanks,
Lee
Posted on Sep 16, 2008
  • 928 Answers
Try resetting the camera and see if this will fix the problem.
1. Press Menu
2. Select the "Setup" tab, select "Reset", and then press the triangle play button
3. use the up and down arrow to select "Reset" and then press SET.
  • Thomas Lim
    Thomas Lim Sep 16, 2008
    May i ask if you did a reset? If that still does not work I would suggest having the unit serviced
  • 6,487 Answers
There's a possibility that there's some dirt get in to your lens , that's why it wont close now , so the next xtep that you can do here is to do some cleaning on that camera lens if you have any experience in cleaning a caemar lens like that you can go ahead and dismantle it then clean the l;ens using an ethyl alcohol , but if you're not familiar with that better ask someone who have experience with that type of cleaning....
Hope that helps...........
  • Mark Gil
    Mark Gil Sep 16, 2008
    i will suggest you now to take it to a service center near your and let them check this unit for possible mechanical problem....
    Brigadier General:
  • 3,614 Answers
Try to remove the camera battery and put it back. this can be happen on such a hardware malfunction, just try to remove it and let me know here again.
micro
  • micromaster
    micromaster Sep 16, 2008
    1. If your camera is still under warranty, the best thing you can do
      is to take it to the nearest official repair shop and they should fix
      it for free.
    2. If your camera is out of warranty, or if the manufacturer refuses
      to repair it for free (happens sometimes if for example they suspect
      the camera has not been treated properly) you can try the following
      methods to repair it yourself.
    3. First, make sure your camera has fresh batteries and it is in recording mode.
    4. Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
    5. Try compressed air. With a fine tip blow off gun and dry compressed
      air (20 lbs) set the tip between the lens turret and the camera body
      and turn on the air while moving the tip around the lens. It should
      remove all dust and sand. Turn the camera on and it should function
      fine.
    6. Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
    7. Try forcing the camera lens. Turn off the camera. Place it on the
      back with the lens facing up and take a look at the spacing between the
      lens and the lens housing. If you notice that the gap is not even all
      the way around the lens, the problem should be easy to fix. This type
      of a problem usually occurs if the camera was dropped while the lens
      was extended. Simply - VERY GENTLY - press down the lens on the side
      where the gap is the biggest. You should hear a "click" as it pops back
      into place. Try powering the camera back on.
    8. If the lens doesn't extend at all or it extends, and then retracts
      again, do the following. Turn the camera off. Take the camera in one
      hand and with the other gently take one part of the lens and gently
      move it round in a circular movement. Do so with both sections of the
      lens. You will hear a "click" as it pops back in place. Power the
      camera on.
    9. Another version of this fix would be to pull and twist on the
      largest ring of the lens while turning the camera on. Listen for a
      "click". If at first the focus seems to be off, turn the camera on and
      off and take lots of pictures, close ups and distance. Focus should
      slowly start improving.
How to unlock the casio exilim camera ex-z850
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 19, 2010 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Casio Z850 froze & nothing works
just took out battery and memory card and out them back in.
Jun 05, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
LENS ERROR
then it's time to take it in for a repair estimate.
Apr 24, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Exilim lens
I had the same problem the thing my lens was stuck and i wiggled the lens around a little but and it closed and works fine now.. I hope thats all your problem is.
Sep 14, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Dropped camera on wood floor, now it beeps when I press on but nothing happens. Telescopic lens does not close. Cannot see images or take pics.
Both of those are "lens errors". That's what happens when your lens has had damage done to it. The only way to fix it is to send it into repairs. Call repairs at 800-706-2534 option 2 and they can tell you where to send it.
Jun 14, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Casio EX-Z850 how to change time & dates
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 08, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Casio EXILIM ZOOM EX-Z850 Zoom button doesnt work
You have to send it in to repairs. You're lucky that the lens even still comes out.
Apr 14, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Cameras Logo
57 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
