Question about Edirol FA-66 (EDIFA66) Audio Input
Problem with FA-66
How do I only decrease the volume of the monitors (theyre connected to output 1+2) without decreasing the headphone volume at the same time? -on the Edirol FA-66 Soundcard
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you using this on a Vista computer?
  • Tim Babcock
    I'll have to look that up.
  • 2,794 Answers
Judging from the wiring diagram on the cover, the headphones are connected to the same output lines as 1 & 2. When you increase or lower the monitors. So do the headsets. The only way to get around it is to find a pair of headsets with at volume control into the wiring of the headsets or plug the monitors into outputs 3 & 4.
Here is the book I saw
Posted on Sep 15, 2008
Denon receiver problems
Check sound from headphones. These models have been known to have bad headphone jacks that make the unit think there are headphones plugged in even when there isn't. Sometimes just plugging in headphones and unplugging them will fix it for a while.
Apr 26, 2013 | Denon AVR-689 7.1 Channel Home Theater AV...
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
I have located the volume control button on my monitor but every time i pres it it decreases the volume. I need to Increase the volume not decrease it. Help
You've failed to mention the make/model of your monitor. There should not be a single button for volume control, as volume control is either up or down. Try the button above the one you've been pushing.
May 11, 2011 | Computers & Internet
Can decrease volume down, but can't get it up. now i barely listen the music playing on it. afraid to press volume decrease button
The problem is, is that there is a shortage in the headphones. When a headphone shorts out it can have your problem, or it can get really stadicy. If it's the player itself, then... This is a hard thing to solve, but if the volume button's are sticky then that would explain the turning lower part. What i see here is that there is the 1. Internal problem 2. The person's fault and 3. The manufacture's fault. I can't explain how many times i have had to send in my Mp3 Player in for it's warrenty becuase of that same problem.
Oct 30, 2010 | Oakley Thump MP3 Player
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
Seem to have developed a problem with my audio recording and playback using Roland's FA-66 (Editrol). I use Cakewalk SONAR, Sony Sound Forge and Vegas Video softwares, and all of them show the same sound...
www.rolawww.scottyp-music.com/geardos/?p=21 nd.com/products/en/_support/dld.cfm?...FA-66
try these 2 sites, i believe they have some good info you need and will probably solve your issue. ive heard some horror stories about norton. unistall and see what comes about. it seems as though too many connections are going to screw this item up and norton will do the same.
Nov 15, 2009 | Edirol FA-66 Sound Card
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
Problem with stereo output on Edirol FA-66
Possibly, your adapter of small to big is not a stereo adapter. Seems like a mono adapter.
Jun 15, 2009 | Edirol FA-66 Sound Card
Volume when on tuner is very different than when on DTV
Under the input menu, there is a volume trim function which allow you to increase or decrease the volume level of each input. It is designed so that the volume of different components can be matched to prevent a blast of sound when changing to a lounder output. You can increase the alevel of the dtv input, and decrease the level of the tuner. Tuner volumes are usually high.
Jan 24, 2009 | Yamaha RX-V1400 Receiver
Edirol FA-66 (EDIFA66) Audio Input Logo
373 people viewed this question
Top Edirol Televison & Video Experts
Electro Med Services...
Are you an Edirol Televison and Video Expert? Answer questions, earn points and help others
