Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman Garage Opener /
Believe the garage door opener limit switch assembly is bad( 41D3452) The pinion gear not engaging, presume the common contact should travel back and forth when opening and closing.
  • ernievzla Nov 21, 2008
    my garage door dont go down, check sensors, and red light is flashing, but green is off, sensors are aligned
Door will not go down unless you hold down the inside botton.
Posted on Oct 14, 2008
I just had the same problem with my Sears Opener. It has the "Protector System" (safety sensors). When I checked the sensor indicator light on the receivinng eye the green light had a slight flicker. I cleaned both the sending eye and receiving eye lens of dust and cob webs, then realigned the receiving sensor for a steady green indicator light. When I checked the door function it now works fine. I quess over time, temperature, and viberation the sensors become dirty and get out of alignment, as no one had tampered with the sensor alignment prior to this. Hope this works for you.
Posted on Oct 19, 2008
Door shuts but opens without touch button , just fitted new worm gear this is a chamberlain model41a2817
If the unit was working before replacement and you lowered opener power head and removed wiring ensure that the safety sensors are wired correctly.LIFTMASTER Garage Door Openers 41D3452 Limit Switch AssemblyPerhaps your limit switches may need to reset, (located close to gear assembly) also the closing force may need to be adjusted. Good luck
Aug 18, 2017 | Building Materials
Motor will not stop.
The wiring for the limit switch assembly is:
Yellow wire to the up limit contact
Gray wire to the center contact
Brown wire to the down limit contact
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Older garage door opener, 1/2 hp limit switch does not stop door in up position keeps trying and does not shut off?
If this is a Craftsman you need to remove the cover and you can then watch the limit switch assembly. If it is a Genie the up limit contact is probably broken
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener is malfunctioning
It sounds like the gear and sprocket assembly has gone bad. This would cause the symptoms you have.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP chain drive garage door opener.
You need to take the cover off the motor unit and watch how the limit switch assembly works. If the door is not stopping when the contacts make then you have a bad logic board.
Jun 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
check the end shaft platic cap is installed and runs freely between the rpm sensors.. that might be ur problem..
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Limit switch not rotating when garage door moving up
CHECK TO SEE IF THE UNIT CAN BE CLICKED IN PLACE TIGHTER.
IS THE LIMIT SWITCH BEING DRIVEN BY THE GEAR ON THE DRIVE SHAFT??
IF THE DRIVE SHAFT IS TUNING THE LIMIT ASSY AND IT IS PROPERLY IN PLACE REPLACE THE LIMIT ASSY.
Nov 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,027 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
