Question about Polaroid FLM-323B Television
HDTV selection I have a 37" Polaroid FLM 373B HDTV with built in tuner, I am having problems connecting a HD antenna into it. When it is connected it does not allow me to select the HDTV option on the menu. When you scroll over to the HDTV tab it disappears and the remote disfunctions, TV does not respond. Tried others and same situation each time. TV starts to blink in and out. What can I do?
  • Shondre Johnson Sep 16, 2008
    I AM NOT INTERESTED IN A PLAN!
  • 3 Answers
SOURCE: 37"LCD television FLM-373B we have had our tv alittle over a year and now
It seems that the manufacturer of the Polaroid FLM-373b HDTV either used the wrong parts or there is a design problem. I found someone on the internet who said they replaced two capacitors on the power board and it started working just fine. I took the power board out of mine and sure enough the two caps with the 10v markings were swelled. I replaced them with two 25v caps and it is working just fine. All the other caps on the power board were 16v and above. So, I would assume they were shipped the wrong parts or they just put the wrong caps in to begin with. If you want to send me your power board I will fix it for $50.00 plus shipping.
send inquires to:
mott414@@yahoo.com (remove second @)
Posted on Jul 08, 2008
  • 3 Answers
SOURCE: hdtv
It means that it has the HD decoder built in to the tv
Posted on Oct 15, 2008
SOURCE: 37"polaroid FLM-373B
Hey guys, I read the solution about replacing the 10v 1000muf caps in the power supply module. I was ready to throw the set out. I tore apart an old old old Jerrold 700 converter and found a couple of caps that were 1000muf. One was 26v and the other was 52v. Anyway, the set works great now and I now have a 37" LCD in my shop to watch the Leafs!!!!
Thanks for the advice.
StereoSteve.
Posted on Dec 16, 2008
Shuttle83
  • 1139 Answers
SOURCE: i have no sound when i plug my hdmi cable in to my
Hello jrcgoat, First check your audio settings by going to the TV menu, making sure mute is off, and audio is set to mid range. Once that is done, if possible use the other HDMI port. Now if the other port is not functioning then the problem is in the circuits after the HDMI buss, however if the other port funcions the the problem is in the actual HDMI interface. Usually the port and the support circuits are on the same board, if they are for simplicity I would say to replace the board. However, if you have a background in electronics and have the equipment to do so, I believe that you can troubleshoot this issue and resolve it. The HDMI port is not the most stable of interfaces, that is why I always tell folks to turn off and unplug the TV and all devices until the HDMI interface is connected to the other device and then plug the TV and device in and turn them on. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 11, 2009
StevenPolloc
  • 28 Answers
SOURCE: FLM-323B HD blue screen, no signal.
for the remote change battery or get new remote, For the TV make sure that your cable is plugged in properly and not half out. or has it previously been wet. Reason because it sounds like your TV has had a static charge.
Posted on Jul 03, 2009
Tip
Polaroid FLX-374 Service Manual Download
Download Polaroid FLX-374 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLX-374 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLX-374LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLX-374 Manual Download
on May 01, 2010 | Polaroid FLX-374 37 in. LCD TV
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
Tip
Download Polaroid FLX-374 LCD HDTV Manual
Have you misplaced your Polaroid FLX-374 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLX-374 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
Tip
Polaroid FLM-3734B Service Manual Download
Download Polaroid FLM-3734B LCD HDTV Service Manual
Have you misplaced your Polaroid FLM-3734B LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3734BLCD HDTV Service Manual?
I hope that helps.
Polaroid FLM-3734B Manual Download
on May 01, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Tip
Download Polaroid FLM-3743B LCD HDTV Manual
Have you misplaced your Polaroid FLM-3734B LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3734B LCD HDTV Users Guide?
Follow this link
I hope that helps.
Tip
Polaroid FLM-373B Manual Download
Download Polaroid FLM-373B LCD HDTV Manual
Have you misplaced your Polaroid FLM-373B LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-373B LCD HDTV Users Guide?
Follow this link
I hope that helps.
Polaroid FLM-373B Service Manual Download
on May 01, 2010 | Televison & Video
Tip
Download Polaroid FLM-373B LCD HDTV Service Manual
Have you misplaced your Polaroid FLM-373B LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-373BLCD HDTV Service Manual?
I hope that helps.
Tip
I hope that helps.
on May 01, 2010 | Polaroid FLM-323B Television
Tip
Follow this link
I hope that helps.
Polaroid FLM-323B Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
