Question about Philips CDR800 4-Disc CD Recorder
Philips CDR800 Player/recorder service manual
I am looking for a service manual for the above mentioned player/recorder. The problem is that the player started to give problems recording cds then it stopped all together. Need the service manual to have it repaired.
  • mycro1963 Jan 27, 2009
    wont read disc when inserted into record tray
  • 158 Answers
SOURCE: philips dvd player 616k
have you tried to record in sp then playback on same machine if this works then your drum for recording in lp or if yours has ep mode may need replacing as pre recordings are ok you need to get it serviced. hope this goes well
Posted on Aug 14, 2007
SOURCE: UNKNOWn disc type
Me too - I've had a DVR3305/05 for just over a year and yesterday after using a lens cleaning disc it refuses to play anything !!! My advise is to stay away from Philips !!!
Posted on Dec 21, 2007
  • 3 Answers
SOURCE: RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Posted on Dec 23, 2007
SOURCE: Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Posted on Jun 17, 2008
simplemitch
  • 752 Answers
SOURCE: External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Posted on Sep 09, 2008
Cd not reading
This happens sometime when the drop
down menu in the recording program is
not set correctly for the dvd recorder it
may be set for another recording device
or the dvd player. If this in not the case
try removelng the dvd recorder in device
manager and leting it reinstall
Nov 21, 2007 | Philips DVDR630VR DVD Recorder/VCR
Copying VCR cassette to CD
Seems the DVD is only a player, not a recorder. If the manual did not explane how to do it most likely it will not.
Dec 12, 2011 | Philips DVP3150V/37 DVD Player/VCR
I record movies on windows 7 media centre and can't play them on my iriver e100 player. I also can't watch mp4 format. What do I need?
Greetings - your IRiver E100 only plays certain .avi files and versions of Windows Media (.wmv) files.
To use your media center and MP4 files you would have to obtain converter software that would convert the files to be compatible with your player. Recording TV shows creates files which are incompatible with the E100 as are MP4 files.
For the TV recordings you would have to do as follows:
Forget the mention of IOS device above - you need to do the same step.
You then have to convert them to files that the player can use. I'm told this software works well and is only $9.95 (USD). Take a look HERE. (I have no connection with this company).
For other files (like MP4 files) you just have to use the converter software I mentioned above and don't need the first step I displayed above.
Enjoy your Video.
Mikeywaf
May 14, 2011 | iRiver E100 Digital Media Player
My 760 recorder keeps show no audio when I try to record. I've tried hooking it up serval ways no luck. However it plays perfect.
You can not use normal Data CDs. Use CD-R Digital Audio CDs or CD-R Audio recordable CDs. If you use correct Digital Audio Recordable CDs, it will show OPC. Once you press Recording, audio out is coming. Otherwise you can not listing to audio. Please read manual carefully. Above will solve your matter.
From Channa
May 10, 2011 | Philips CDR760 CD Player
After a Sk to HD upgrade [which should not have affected my DVD recorder], my Philips DVDR3480 will only play pre-recorded DVDs. For files in divx format, even files originally written on the same...
www.p4c.philips.com/files/d/dvdr3480.../dvdr3480_58_pss_aen.pdf
Hi, please find above your user manual and your service manual below/
http://www.fixdevice.com/smanuals/file/38174.html
OK perhaps you may need to now upgrade the firmware or re-set up the player again using the service mode, please find all this info in these manual above. It may just be co-incidental, or perhaps your laser assembly is going faulty. Often though, it has to do with CODECs not being installed. or activated, you need to check your manuals for information.
I would wonder if the swap out, hasn't reset all your playback settings? Or the Brain, is thinking it is a differing unit now? and setting it up again may just fix your problem. Anyway please use the service and repair manual's troubleshooting procedures you should be able to isolate and hopefully repair your unit.
Jun 21, 2010 | Philips DVP5140 DVD Player
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
CD Player wont recognise discs keeps saying insert disc.
hello,
clean the lens with a dry cotton bud, and if does not work . change the lens to a new one of the same type. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy parts for the replacement.
May 25, 2010 | Philips CDR800 4-Disc CD Recorder
Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Dec 29, 2007 | Philips DVDR3450H DVD Recorder/HDD...
Philips CDR800 4-Disc CD Recorder Logo
101 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
