Question about Mitsubishi WS-65813 65" Rear Projection HDTV
WS- 65813 Blink Green Light
Dear Troy-
I have a Mitsubishi WS-65813 and the blinking green light syndrome. Sometimes the tv will power up, sometimes I get extended periods (12+ hrs.) where nothing works other than the blinking light. It looks like you have the service repair instructions or some other fix. I have read that I may need to replace 4 capacitors on the DM board.
Please send me any instructions you have if you can.
Thanks in advance-
Michael Baltay michael_baltay@monitor.com
  • scottswire Nov 19, 2008
    same problem Wont start up done all unplug stuff and reset
    Help
    scottswire@comcast.net
  • tvsal Dec 04, 2008
    Started on 12/03/08 light started to blink.I tried to unplug the tv for an hour still kept blinking.I also tried to press the reset button and the light keeps on blinking.What a nightmare!!!!!!!
5 Suggested Answers
  • 1694 Answers
SOURCE: Blinking green light stays on and TV won't turn on.
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Posted on Sep 26, 2007
Green Blinking Light - Order a DM Modual from Mitsubishi. Read the plug labels when reinstalling.
Posted on Dec 14, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WS 55809 Rear projection TV
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WS-65513 Green Blinking LED Fix Request
you can obtain the service manual at the following link they email it to you and you will recieve free support and if you request they will send you the step by step proceedure for the DM repair through their tech support program. This is all free when you purchase a service manual. You would need the VZ23 series mitsubishi manual. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Apr 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi TV WS-65713
you can get the service manual and detailed instructions on that repair by going to the following link.
Posted on May 31, 2008
Mitsubishi ws-73711 turns on (I see a green power light) then off
press and hold 'device ' and 'menu' buttons on front of tv until the power light starts to blink out an error code . It will blink a few then pause and....repeat.. . Count the blinks. It is giving a two digit error code and repeating it 3 or 4 times. 22=low voltage short detected usually caused by the convergenge amp I.C. .12=normal
Oct 03, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
WS-65513 Blinking Green Light
I have a Mitsubishi MITWS-65813.
The green led light constantly blinks. I tried the reset button and green light is still blinking. I unplug the tv, waited a few days, then plugged the tv back in, the green light still blinks. I have a lot of experience with soldering. Do you have any suggestions or can send repair directions/protocol for the DM board.
via email? Thank you in advance for your help. Your help is much appreciated!
Sep 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi TV WS-65713
mine is doing the same thing. It started when I unplugged it to move to a new location. Can some one please help me!!!!
Sep 19, 2008 | Televison & Video
Green light
Green light keeps bleeking and tv won't turn on at all.
Jul 19, 2008 | Mitsubishi WS-65813 65" Rear Projection...
May 31, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
