Question about Gateway FPD1975W 19" LCD Monitor
Vista shows monitor as Analog
My settings are showing the monitor as a non- PnP analog. how do i get Vista to recognize the monitor as the PnP digital it is?
  • Gateway Master
  • 5,568 Answers
Are you actually interfacing via the DVI-D connection or the 15 pin analog 'D' connector? Your monitor is equipped with both according to its specs.
Posted on Oct 11, 2008
ACER P223W Monitor Ghosting (Multi-Mon Setup Win8)
Hummmm.... are both monitors connected to the same surge protector?
I had a similar problem with 2 monitors and a Brother Laser Printer (with a long USB cable), where the Brother was connected to a different AC outlet connecting to a different breaker! No fair...
That happened because that 'Brother' outlet was part of a new room addition... and hence a 'new/different' circuit breaker.
Once I connected the Brother to the same surge protector my video problems went away. And yes, the "grounds" are connected properly at both outlets... go figure.
Anthony
Nov 22, 2017 | Acer P223W 22 inch Monitor
Windows detected my monitor as generic non pnp monitor and when i installed the inf file for lg monitor and updated and rebound to generic non pnp monitorit says device on vga and when i
I see you are having issues with you LG monitor.
What type of video card do you have on your computer? if I may ask.
And also did the LG Monitor come with a disc to install the Monitor.
The VGA means it is using VGA a a mode or type of cable connection for the Video, what cable are you using? are you using an HDMI connection for the Monitor/LCD or is it the Blue Cable on both ends if it is the Blue Cable then that is using VGA so it will say on VGA meaning it detects the video connection from that cable.
Are you asking because this shows every time you turn the LCD monitor ON , is that correct, if that is the reason it is normal.
The question I see is incomplete? and when you? what happens?windows detected my monitor as generic non pnp monitor and when i installed the inf file for lg monitor and updated and rebound to generic non pnp monitorit says device on vga and when i
Sep 01, 2011 | LG W1941S-PF Monitor
Computer will not recognize
Double-check to see if the cable is properly attached and the monitor is set up for DVI(digital) or RGB(analog) depending on which cable it is. Or you can set it to Auto, that normally works.
If you still cannot get a picture try a different monitor or verify the computer is starting up. Sometimes if you fondle with the memory or other internal components the video will not show, thus the computer is not starting at all.
Feb 19, 2011 | X2Gen MG19MY 19" LCD Monitor
My Westinghouse LCM 22w3 was working great with full res at 19xx x 16xx. Now it is no longer recognized by my Windows Vista system. In Device manager, the monitor shows as a General PnP 17" with res...
I suggest you test your computer by using a different known good monitor. If it works ok you will know your Westinghouse has a fault and if it doesn't you will know there is a problem with your computer (video card maybe?)..
Sep 29, 2017 | Westinghouse Electric LCM-22W3 22 inch LCD...
Windows 7 doesn't recognize my iiyama Vision Master Pro 450 Monitor, what to do?
My Iiyama Vision Master Pro 450 works with Windows 7 when connected with a VGA video cable that has 5 BNC RGB connectors that attach to the back of the Iiyama monitor. No driver install was needed; Windows 7 shows my Iiyama monitor as a "Generic Non-PnP Monitor" with 1024x768 resolution.
Jan 13, 2011 | iiyama Vision Master Pro 450 Monitor
Benq G900W Monitor: Settings show as generic non-PnP monitor and
for that purpose you have to insert an AGP card into AGP slot of grade 8X then you can see full resolution because the inbuilt display card does not support to high resolution
Mar 05, 2010 | BenQ G900W Monitor
Running with 2 monitors on a Windows 7 OS.. 2 exact brands / size. main monitor shows the correct driver. 2nd Monitor shows Generic PnP Monitor. How do I get 2nd to show the correct monitor? I tried...
You will need to go into Device Manager, and look at your Monitors listed. One probably lists as Acer AL2016W, the other one lists as Generic PnP Monitor. To fix this, open the Generic PNP Monitor (right click and go to properties). Then choose "Update Driver" button, Select "Browse my computer for driver software", then select "Let me pick from a list of device drivers on my computer".
You should automatically get a list for the Acer AL2016W option. Depending on how it's cabled up and connected, you ay either get Analog, Digital or DisplayPort (or HDMI if that model allows it). Choose the option that's relevant. Now your monitors should list properly.
Nov 30, 2017 | Acer AL2016W 20" LCD Monitor
My HP 9311 Tx does not give display on its LCD screen
after loading Operating system just press F5 and wait for 2-3 seconds. if display not appear try 1-2 times. it will come. plz replt if ur problem solved
Apr 10, 2009 | HP Pavilion dv9000z Notebook
Analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
May 01, 2008 | ViewSonic VP191b 19" LCD Monitor
Driver for KOGI Monitor.
you can try it from driverguid.com or its regional site.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Mar 13, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
148 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
