Question about Acer Aspire 3000 Notebook
How to disable mousepad?
Acer Aspire 5000, how do i disable the touchpad when I have an external USB Mouse plugged in? My hands constantly brush the built-in touchpad mouse and I would like to disable it. Please help, I've tried everything I can think of.
  • AdamHere Sep 16, 2008
    Sandrew,
    Thanks! All set.
  • Anonymous Mar 25, 2014
    no version of windows sees my mousepad
    President:
  • 2,961 Answers
Normally the Fn and F7 key, it's the key with a finger on a square icon, or right click on the touchpad icon in taskbar>pointing device properties and select device settings and then dissable.
Posted on Sep 15, 2008
How to disable touchpad
Go to control panel, click on 'view by: large icons' on the top right if available. Find the mouse icon. Then click on the device settings tab. Tick the 'disable internal pointing device when external USB device is attached'.
That should fix your problem. I'm assuming you have Windows 7, if you don't it still should be fairly similar.
Oct 23, 2012 | Acer Aspire 1681WLMi Notebook
My touchpad is not working for click(touch) operation. I feel that this started happening after plug in a USB mouse
When you plug in a USB mouse, the touchpad is usually automatically disabled. Look in your control panel under Mouse or Pointing devices. You will want to look at the settings to ensure that your touchpad turns back on after you unplug the mouse. If your touchpad is NOT returning to normal functionality after you unplug the mouse, try the "safely remove hardware" option (If you have windows). Look in the lower right corner of your screen. If you have a small green arrow icon that safes "safely remove hardware" when you put the mouse pointer over it, click on it. If the mouse shows up in the list, highlight it, and click Stop. You can then remove the mouse when Windows tells you it's safe to do so. This may then return full functionality of the touchpad. In some cases, the mousepad click functionality will be disabled if a USB mouse is plugged in. It can remain so if the system doesn't fully acknowledge that the mouse has been removed. That's why I'm suggesting to try the "Safely Remove Hardware" option first. If that doesn't work, there may be a physical problem with your touchpad and it will need to be serviced.
Dec 05, 2010 | Acer Computers & Internet
Mousepad not working
Each Touchbad should have basic functionality by default in every Operating system, letting it be used even when no driver is installed. However, try pressing FN and F7 together and see if the touchpad works again. Some people accidently press this FN + F7 key when they mute the sound with the FN + F8 key.
The FN + F7 is there to disable/enable the touchpad as some people use a USB mouse instead of the touchpad.
If you still need the drivers, here are the download links. Please choose desired driver by Operating system and Touchpad brand...
Acer Windows XP TP Drivers Synaptics
Acer Windows XP TP Drivers ALPS
Acer Windows 7 TP Drivers Synaptics
Acer Windows 7 TP Drivers ALPS
Acer Windows Vista TP Drivers Synaptics
May 18, 2010 | Acer Aspire One PC Notebook
Acer 4720z mousepad not working
You may have a function key that can enable/disable it or a setting in the control panel > mouse > pointing devices. Or possibly a BIOS setting to enable/disable.
Apr 08, 2010 | Acer Aspire 4720 Notebook
Touchpad stopped working..I can get a usb mouse to work
It seems to me the drivers for your mousepad may be out dated go to hardware manager and update drivers
if you need help doing this just ask
Thanks
Cbz123
Feb 08, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Feb 01, 2009 | Acer Aspire 3000 Notebook
Mousepad
if you want to disable mouse (touchpad), use Fn+F7.
as you said your touchpad create problem, try to remove battery first (boot up using only ac adapter), battery can cause touchpad not working properly.
Apr 12, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 laptop
Hi, Try pressing the FN+F7 buttons together. This will enables or disables the touchpad.
Cheers!
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
207 people viewed this question
Brian Sullivan
Brian Sullivan
