Question about Toshiba CF19F22 19" TV
Toshiba CF19F22 TV screen too dim.
Screen brighness too low even bright control is at maximum. Can't track from jungle chip because i have not ic pinout or datasheet. Thanks.
  • Toshiba Master
  • 19,396 Answers
It looks like the CRT tube on your TV came at the end of its days, if the tv is 15 years old or so this can be normal.
It may not be woth repairing.
Posted on Sep 14, 2008
  • Ginko
    Ginko Sep 14, 2008
    I dont think this has anything to do with the the jungle chip.
    In the best case it can be color amps ICs.
    The service manual is not available for free download.
    If you need the service manual you can buy it here
    Toshiba
Bright lines in the center of the screen the height is insufficient.replacing Vertical ic La7830,and 3 or 4 condenser no good.Need schematic diagram try to search for the jungle output.tnx more power
This is the vertical deflection IC of a CRT color TV. If you think it is fried then replace it yourself. For a datasheet of this part check the following link:
http://www.rdd-tech.com/product/la7830
If the problem is the jungle output IC cxa2159s could be a problem and not start the power supply. This can cause an error code to know for sure.
Feb 10, 2015 | Televison & Video
In my tv is 10 years old and by the 2007 we replaced with new board(Only the CRT is the old one). Last day I was switched on my tv only sound only came and no picture. I can able to see the menu setting in...
Hello
Your TV is fitted with Toshiba kit I understands from your description. There is a sub-brightness contorl on board [a small preset resistor, which can be adjusted with a small screwdriver] fitted near to the LOT and towards its left side, on board. First try to advance the screen voltage by adjusting the screen control integrated with LOT. Screen control can be located at the bottom. If it does not help, adjust the sub-brighness control. If sub brighness preset is faulty, this kind of fault may also occur. So replace it with a new one. As far as on screen meny display and blue back screen at no signal is there and the sound is Ok, there is no other fault with the kit, other than adjustments. OK.
May 18, 2011 | Televison & Video
How do i get the screen to light up more, its to dim?
Depending on how old your computer is, your lamps may be failing,
Or you may have reduced the brightness, look for two F buttons generally F7 and F8 for screnn brighness, hold down Fn or function button and tap F8 to increase brightness.
Jan 17, 2010 | Toshiba Satellite A75-S226 Notebook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Picture is very dim
there is a problem in the flyback section of the tv set. the fly back has two knobs, one for screen and the other for focus. use the screen knob to adjust the brighness. if it did not help, either check the capacitors around the flyback or change the fly back with a new one. good luck
Jun 01, 2008 | Televison & Video
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Toshiba TV
vertical deflection problem. Vertical output IC, pump up cap, power to output problem, bad connections, jungle IC. Its a good idea to replace all electrolytic caps near the output IC. Bad caps cause it to run hot and self destruct.
Oct 29, 2007 | Toshiba CX36F84 TV
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Televison & Video Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
