ZMate MP3 Mark: I just got a zMate MP3 player. When I hook it up to my PC to put music on the disk, I get a message that says please insert a disk into the F drive. Any ideas how to fix that problem? Your suggestion about the file not being in the root was confusing to me. Could you explain specifically how to do that, in language a newbie can understand? Many thanks, Tara
I don't the configuration of your computer, but it sounds like the F: drive is the zMate player... so if I am correct, the message means there is no memory card in the player. If yours is the same as mine, the "player" itself is a card reader/writer with no memory of its own, and works only when you put an SD card in it (mine actually came free with the purchase of the SD card).
As for the files being in the root, what that means is, when you first use a device it has no subdirectories in it (what Windows calls "folders"). So essentially the card is one big folder with no categories or subdivisions. Like if you built a house with no rooms in it, it would just be one big room with no den, no kitchen, no living room - just one big area.
Since there is just the one huge, unnamed folder, this is called the ROOT. All folders that you create on the memory card are like "branches" that begin at the "root". Most people will create a folder on the card, and call it "My Music" or something like that. Or several folders and call them "Country" and "Rock" and "Hip Hop". Or maybe you'll make a folder for the Beatles, one for Aerosmith, one for Rihanna... you get the idea. If you do NOT make any subfolders, at least on my zMate, then the player can't find the music. You need to make a folder and name it "AUDIO" and put your .mp3 files in that folder.
To make a folder, you first put the card in the player (or in your PC's card reader, if it has one) and then, if you are using the player, you plug that into the USB port on the PC. Windows should open the player in a window, and it looks like it is one of the drives on your PC. If you look in "My Computer" you will see the card and it will have a drive letter higher than C:, and if you have a CD-ROM the letter will be higher than D:. The drive will be listed as a "REMOVABLE DRIVE". When you open up this "drive" you will see no folders, just the root folder (which has no name). Use the mouse to "Right-Click" and then choose "NEW" and then "FOLDER" or use the "FILE" menu at the top of the window, choose "NEW" and then "FOLDER". Windows makes a folder called "New Folder" - change the name to "AUDIO" at this time (just type over the name "New Folder". If you can't type over the name, use the mouse to right-click "New Folder" and choose "Rename" from the menu.
Hope that helps.
Posted on Sep 15, 2008
I got a miniclip mp3 player I try put my music but my computer say please insert disk in E please help
It is seeing the miniclip as drive E: Check with the store you bought it at, they should help you further.
Nov 27, 2014 | Audio Players & Recorders
HOW DO YOU GET THE LIBARAY CHANGE TO DOWNLOAD THE SONG. IT'S ON MY WINDOWNS MEDIA PLAYER AND I CAN'T PUT THIS ON MY MP3 PLAYER.FROM WINDOWS MEDIA PLAYER TO PC LIBARAY ON MY MP3 PLAYER
I to have so many problems with windows media player its a shame... but like all things there is a way around it.
If the music you are trying to put on the mp3 is in windows media player, then you'll need to track it down.. *note- not all removable media comply with windows media player*
If you are using a PC-- desktop, then finding the music should be simple, and found in the folder my music.
Once you have located the music you want to put on your mp3, you'll have to find your mp3 player.
The mp3 player should show up as a removable disk or storage in "my computer".
Once you have found your mp3 as a removable disk, right click it, then go to explore. This should open a folder containing the contents of your mp3 player.
You may see several folders in it, but the one you want to go to is of course music.
From here on its simple... the My Music folder on your computer should still be open.... also the music folder inside your mp3 folder should be open.
Drag and drop the music files from the my music folder to your mp3 folder... a notification and time of the transfer will appear.
When it is done... the music will be added to your mp3 player ..... this process can also be used vice versa, as in getting music from your mp3 to your computer.
Please notify me if there are any problems.. thanxx <(^_^)>
Apr 19, 2009 | RCA OPAL M4001 MP3 Player
Girlfreinds old MP3 player. We have no disk and I cant get it to upload new music. Computer gives the message: 'please insert a disk in drive F:'
The driver you would need would be the one that has the same model number as yours, the mp3 player may say what model it is on the case
Apr 13, 2009 | Audio Players & Recorders
Zmate mp3 player confusing
The A-B music is the repeat button.
Press the first time and you set the start point. Press it again later in the music and you set the end point and for that time on the player just plays from start point to end point and repeat it again. To remove the repaet option just press the A-B button once again. The lock button is to lock all the control buttons so that you don't accidentally press then while in the pocket. To put the music is no secret just insert the mini-usb cable in the zMATE and the computer and it should detect it as a usb drive in the next available drive letter. (if you have a network drive letter in the next available letter it will not appear and you must change the letter in the manage computer system, of course this is for windows systems)
Dec 28, 2008 | Dane-Elec TA-SD0512-D MP3 Player
Zmate mp3 not recognised
Try a different cord, USB port, and bypass any splitters if used. Then try another USB support driver in Device manager.
Dec 28, 2007 | Dane-Elec TA-SD0512-D MP3 Player
E200 microSD card not reading
try to right click the icon of the separate drive and click on explore
Dec 11, 2007 | SanDisk Sansa e200 MP3 Player
Going thru batteries
IF YOU FIND OUT ANYTHING ABOUT THE ZMATE, WILL YOU EMAIL ME? IM TRYING TO FIND OUT WHATS WRONG WITH MY BOYFRIEND"S ZMATE THAT I GAVE TO HIM!! THANKS!! APPRECIATE IT!! : )
Jun 01, 2007 | Dane-Elec TA-SD0512-D MP3 Player
Lexar problem
You need to change your USB Port... try the back of your computer. Or you need a firmware update.
Dec 10, 2006 | Lexar LDP-400 MP3 Player
198 people viewed this question
 Grubhead
Grubhead
