Question about Refrigerators
My Whirlpool Frig, Model ER2CHMXPL00 has begun freezing foods stored in the back of the refrigerator part of the unit.
  • Anonymous Mar 22, 2009
    Mine drips water in the back, and/freezes that water, and food.
  • seananstead Apr 05, 2009
    my frig drips and freezes
Sea Breeze
  • 4654 Answers
SOURCE: Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Posted on Oct 27, 2007
mikedurland
  • 481 Answers
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
huuum
  • 750 Answers
SOURCE: Side by Side Whirlpool Refrigerator: Refrigerator is freezing food
Hi, riverbyfarm
You did try what i would of recommended first!
The resetting of the system by, turning off the controls of the freezer and the fridge first and then unplugging it or if you can't reach the plug, to throw the breaker off for 5 minutes!
That is a possibility in the order that I described!!!!!
Second I ask, is the freezer packed full to the hilt with packages?
In some refrigerators if the frozen food covers the air vents in the freezer cause they are plied sky high and deep in the freezer it can cause a problem.
The freezer and fridge share the air and have to have the vents or passages free so to allow sharing of the cold air!
Let me know if the measures as I prescribed have an affect.
Waiting for your reply!
Bless You Huuum
Please do not forget to enter a rating here before you sign off.
Thank You.
Posted on Sep 21, 2008
  • 15 Answers
SOURCE: my norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Posted on Jun 17, 2009
SOURCE: food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Posted on Jun 24, 2009
My whirlpool side by side frig. model#gsf26c4exy03 freezes up the food side
There are return vents located on the wall that separates the freezer and the fridge. Make sure they are not blocked up with ice. A hair dryer can be used to clear them.
Dec 01, 2016 | Whirlpool Refrigerators
Whirlpool refrigerator ER2CHMXPL00 & leak
If you have water leaking into the fresh food section of the refrigerator, then the condensate drain if either frozen at the evaporator OR clogged at the drain pan or both. There are air vents in the top of the fresh food section to allow cold air down from the evaporator compartment and return air up from the fresh food section, and these holes cannot be covered or closed off. Check the drain trough under the evaporator for ice build up. Also check that there is nothing stopping the water flow down at the drain pan. If there is no water in the pan under the refrigerator down by the compressor, you have a restriction that needs to be cleared.
Jun 25, 2016 | Whirlpool Refrigerators
Whirlpool ed25rf refrigerator side freezing on bottom
your evaporator motor may be going bad also check to see if your condensing unit and fan motor are clean this can cause similar problems.
Dec 11, 2013 | Whirlpool 25.2 cu. ft. Side-by-Side...
Whirlpool ER2CHMXPL00 freezer is frosting up
Lets start by going inside your fresh food compartment and see if you can find a round hole most times covered by a plastic plug to hide opening. Remove plug and place a flathead screwdriver in opening and slowly turn the defrost timer clockwiseuntil you hear compressor and fans stop. This is called forcing manual defrost. After a few moments you should hear some sizzle or crackle noise coming from freezer compartment. That will be the defrost heater warming up the unmelted frost. Click Here=> ER2CHMXPL00 Liner Parts See item location 4? That is the defrost timer While the freezer has been set manually in defrost the defrost timer should be trying to come out of defrost itself after about 25 minutes. If it does not come out of defrost simply turn clockwise until the compressor restarts. If you need to do this replace the defrost timer.
482493 Defrost Timer Kit
If doing the above does not help you will need to manually defrost the freezer with a hair drier. Unplug refrigerator and remove the rear panel in back of your freezer. This is where you will see the defrost heater. Click Here=> ER2CHMXPL00 Unit Parts
2315530 Defrost Heater Assembly
On that same page instructions are in a video on how to test the defrost heater. At top of this solutionI mentione the Liner Parts item number 25 is the=> 4387503 Defrost Thermostat
Most likely the defrost timer is the part that is needing replaced. If not then the other two parts listed here are very possible reasons for the defrost failure.
ER2CHMXPL00 Repair Parts List
You may need Adobe Reader if you don't already have to open the PDF files Click Here=> Adobe Reader
User Manuals can be found here=> sea_breeze_247.jpg Whirlpool
I will be here should you have any questions, Thanks Sea Breeze
Sep 24, 2011 | Whirlpool Refrigerators
Model ER2CHMXPL00. Some of the water freeze on the
This is most likely caused because the defrost condensate drain below the evaporator is frozen over or blocked further down the drain line. You will need to remove the rear cover unplug the refrigerator and defrost the drain pan with a hair dryer until you ar able to pour water with a mixture of clorox and allow to flow to the pan below your refrigerator. I have more information on the link below. Click on the link and read the complete page and use the parts that refer to your leaking problem. If you need further assistance please feel free to let me know. Thanks, Sea breeze
Click Link Below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 25, 2009 | Whirlpool Refrigerators
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Food freezing in refrigerator section of frig.
Sep 01, 2008 | Refrigerators
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
