Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears garage door opener
My door will eventually open, but it takes several attempts. Each time the door will go up some and to different heights, but not all the way up. Eventually it will open all the way.
  • 504 Answers
Sounds like a broken spring.
Look for a gap in the spring above the door.
Try disconnecting the door with the rope and see if it lifts manually.
Don't continue to use the opener if the spring is broken it will ruin your gear kit in the opener.
Hope this helps.
Posted on May 29, 2010
My sears Craftsman 1/2 HP garage opener starts and quickly stops with a ****. sometimes only moving the door a inch or so. Lights on opener flash once, somethings power completely seems to go off... power...
Make sure all the connections are tight on the rear of the motor housing. The terminals where all those white wires go must be tight. Also make sure the plug into the wall is snug and not sloppy.
Jul 19, 2012 | Sears Craftsman LiftMaster Chamberlain...
Keypad won't program to garage door opener, tried several times, keypad easily programs to 2nd garage door of 3 car garage, but not to main garage door. Need main garage door to open with keypad. Changed...
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Our Craftsman garage door opener does not work. When we push the keypad to lower the door the light flashes several times and the door does not move. If I hold the button down the door will low but will...
There are a number of things that could cause this. The first thing I would try is to make sure that the sensors lenses at each end are clean. Second, make sure that the sensors are lined up. This will take some trial and error. Adjust the sensor direction and try the opener button. Eventually you should get the sensors aligned and the door should work.
The chances are that one of the sensors has been bumped and misaligned.
Also, spray the wheels in the tracks with WD-40, Jiggaloo or a silicon spray such to make sure that the wheels turn freely.
Please make sure to rate this solution. Thanks.
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Code Remote and other remotes do not all work at the same time.
Either your keypad has reverted to an earlier technology and will no longer work properly with your opener or you have the wrong keypad. Either way take the model number off the main unit and get the correct keypad.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close unless i push button on wall several times
You probably have a stripped gear inside opener. Take off cover and the bottom will be filled with white flakes from stripped gear
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
54 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
