Water runs, but tub does not fill on whirlpool washer
  • pattib4u Oct 07, 2008
    at intial cycle start tub does not fill up, water runs continuously. moving the switch to the wash part of the cycle produces only a hum/buzzing sound out of the switch (or dial)
    Sniper:
  • 88 Answers
Well...if the water is running, the tub is not filling, and you don't have water all over the floor, your drain hose is installed too deep in the drain pipe, or just installed too low, so that the water is simply running out of the machine and out the drain hose.
Posted on Sep 14, 2008
Oceti
  • 51 Answers
SOURCE: GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
  • 10 Answers
SOURCE: Whirlpool Calypso Washer: No water fill intermittent
Check the hose from the tub to the pressure switch, make sure its clear and the reservoir on the tub is clean.
Posted on Oct 22, 2008
SOURCE: Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
Posted on May 08, 2009
bozcro
  • 867 Answers
SOURCE: whirlpool duet washer fills with water when not running
one of the control valves (hot or cold) is not closing the water supply, most likely leaking so the electronics are good. one of the valves needs replacing, but if you dont want to spend the money just shut the water supply off at the water supply taps.
Posted on Jul 17, 2009
washdryman
  • 154 Answers
SOURCE: Whirlpool /Roper washer won't drain or agitate.
LID CONTROL SWITCH BAD
Posted on Feb 07, 2010
Water run in tub when washer is off and leaks all over, this is a built in whirlpool dishwasher
If it's clean water the fill valve is bad turn water supplies off see if leak stops. Is it still leaked with water supply turned off check drain hose could be to low causing drain water to back fill into tub
Mar 30, 2016 | Washing Machines
My Whirlpool washer fills up but won't stop poring into the washer. Is this something that is repairable?
Your water level switch could be defective. This switch has a plastic 1/4 hose connected from your tub to the switch. (should be easy to find.) Make sure this hose is connected to your tub and switch and the line has no holes. It is easy to test the switch by disconnecting the line from the tub and while water is flowing into your washer, Blow into the line. The pressure will stop the water flow. If not, Bad level switch.
Level switch part# W10339333
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool WTW5100SQ
When I turn the washer on the water runs on floor istead of filling tub
the hose which is conected from the water cellunoid to the wash tub is badly damaged and therefore leaking
Feb 20, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Aug 15, 2009 | Whirlpool Washing Machines
The water just runs in my roper whirlpool washer and never fills up and wash the clothes
It sounds like the drain hose may be below the tub level. This will syphon the water out before it ever fills up enough to turn off. The drain hose should go into the plumbing drain at a height above the top level of the tub. Hope this helps!
May 18, 2009 | Whirlpool Washing Machines
Oct 21, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Wahser top loader
possibly cold water should be running into the tub at the same time as the cold to regulate the temp.by only having the hot on, it could possibly have timed out and while still being short of water
Jul 08, 2008 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool washer
the Pressure switch is bad (also called Water level switch) there is a small hose from the tub that runs up to it ..The tub will need top be empty when this part is changed
Mar 02, 2008 | Washing Machines
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
