Check that there is nothing clogging the inlet to the pump below the strainer at the bottom of the machine and slowing down water getting to the pump. This will mean stripping down much of the bottom of the machine, but is unavoidable. Also check that the drain line is not blocked. If there are no problems there, the change over valve may be leaking and returning some of the water to the machine instead of draining it out.
Could be many reasons for the bottom drawer to hold water.
It could be leaky top drawer causing water to collect in the bottom drawer. Check if water collects when top drawer is running.
It could be blockage in the bottom drawer drainage which can be fixed by cleaning the filter plate and the drain sump. If the drain pump is not running during drain cycle then you will have to replace the drain pump motor.
Hi Thanks
for using FixYa. Dishwasher not draining properly or not draining at all issues
can arise due to different reasons. Usually, these issues are related to
kinked hoses, knocked out disposer unit (if connected with the dishwasher drain
hose) & clogged drain pump & filter. Also note that dishwashers do not
drain completely after a finished cycle and this is normal. Dishwashers are
designed to leave some water in the unit to ensure that the heating element
doesn’t overheat. If you suddenly begin to experience a large amount of water
being retained in your dishwasher, you have a problem. Some of the most common
reasons include that the drain hose isn’t working properly, the drain pump
isn’t working correctly, or possibly there is a plumbing problem in your home’s
drain lines. First check whether the drain is not clogged or blocked and the
line is not kinked. Check all the hoses for blockages & also clean the air
gap. If you have checked the drain hose and can’t locate the problem, then it
is an issue with the drain pump of the dishwasher. Please do rate the
solution if the issue is resolved or post a comment for further assistance. Thanks Rylee
Hi Thanks
for using FixYa. Check the water temperature by using a thermometer
inside the dishwasher to measure the water temp. It should be as close to 125
degree F to 140 degree F as possible.
This would have happened as the
dishwasher was overloaded with more than prescribed number of dishes. Check the
spray arm and pump cover for splits or leaks. As the dishwasher
is not draining properly, this issue is related to kinked hoses, knocked out
disposer unit (if connected with the dishwasher drain hose) & clogged drain
pump & filter. Also note that dishwashers do not drain
completely after a finished cycle and this is normal. Dishwashers are designed
to leave some water in the unit to ensure that the heating element doesn’t
overheat. If you suddenly begin to experience a large amount of water being
drain lines. If you have checked the air gap and the drain hose and can’t
locate the problem, then it is an issue with the drain pump of the dishwasher. Please do
accept the solution if the issue is resolved or else revert for further assistance. Thanks Rylee
Thanks for using FixYa.
Dishwasher not draining properly or not draining at all issues can arise due
to different reasons. Usually, these issues are related to kinked hoses,
knocked out disposer unit (if connected with the dishwasher drain hose) &
drain lines.
not clogged or blocked and the line is not kinked. Check all the hoses for
blockages & also clean the air gap. Has the disposer been replaced
recently? If so, chances are the knockout is still in place. Simply remove the
drain hose from the disposer, and knock out the plug. If the disposer has not
been replaced, try removing the drain hose from the disposer and use a wet-dry
vacuum (prepared for water, of course) to **** any water (and hopefully anything
else) from the drain line. Then reconnect the hose, and test the unit. If you
have checked the air gap and the drain hose and can’t locate the problem, then
Please do rate the solution and revert for further
assistance.
If your amp is less than 5 years old you maybe able to get it fixed for free at http://www.domgen.com check it out we have all our contents covered. This is better than your normal home insurance.
Don't matter you could claim 100 times and never loose out.
check it out!
Also don't 4get to leave me feedback
cheers
raverbaby01
