Question about Eureka Vacuums
I boouhgt not long ago a Eureka, the Boss samartVac. 4870K wide track I have misplaced the little instruction booclet It be possible to sent me by te wegg or at home one? my e-mail: beatriztruxton@hotmail.com, I was even able to sent the guarante card. My address: Mrs. Beatriz Truxton !416 Scenic Drive Alamogordo, NM 88310 I got mine in Walmart in town. Thanks for your help.B.T.
reddevil6
  • 1673 Answers
SOURCE: BOSS 5851 Wide Track, 12 Amp
The top comes off to get to the belt and brush roll. Did you check the brush roll to make sure that the ends turn freely, or is one not turning, the belt is a lon life "U" part #61120A. The brush roll is what drives the vacuum, but if brush roll or belt is bad, then it won't drive it.
Posted on Feb 05, 2008
SOURCE: looking for Eureka belt 70646A for a Eureka The Boss upright
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Posted on Aug 06, 2008
  • 833 Answers
SOURCE: can't figure out how to get the belt around vacuum motor shaft
I am assuming you are referring to the beater bar belt. You will either find a release lever on each side or a small screw and bar restraining the bearing that holds the bar in place. Removing whichever of these you find will allow you to install the new belt. Clean up the dirt accumulation on the bearings while it is apart.
Posted on Dec 31, 2008
nwj2468
  • 76 Answers
SOURCE: My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Posted on Apr 19, 2009
  • 33 Answers
SOURCE: It is not clear how to access the front spool on a
The shiny spool is the mechanism that stops the brushroll (brushroll control). The belt only slips around the brushroll, and the motor spindle.
Posted on May 19, 2009
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
How do i change the belt on the eureka boss capture vacuum cleaner
Here is a link to the belts you need and a manual you can view which has instructions:
Eureka Boss Capture Belt
Owner's Guide (3.06 MB download)
Dec 04, 2009 | Vacuums
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka Wide Track Superlite vacuum roller brush motor
Don't know if you can find something that will work, Eureka doesn't make these motors available thru them. Try some local shops or a place that sells small motors.
Jun 14, 2008 | Eureka 431A Optima Bagless Upright Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12164&thid=669867
Posted by mjtnm on Jun 14, 2008
The brush motor went out. Is it possible to buy one and splice it to the existing wires? Where can I buy one? The vacuum is model #409 the number on the dead motor is: DA-20L-2001, 17.5V DC AOM 4293S
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 421A EZ Kleen Bagless Stick Vacuum. Yes, you can replace the power nozzle motor in the head of the Eureka 421A EZ Kleen Bagless Stick Vacuum by either contacting the local vacuum cleaner dealer in your area or to contact the Eureka factory and ask for cust serv or tech support or parts and they will direct you to the correct dept to order the P/N motor so that you can install it and get on with your cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 14, 2008 | Eureka 421A EZ Kleen Bagless Stick Vacuum
Looking for Eureka belt 70646A for a Eureka The Boss upright
Mar 08, 2008 | Vacuums
Feb 03, 2008 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
27 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
