Question about Sport & Outdoor - Others
Coleman TSR RV air conditioner doesn't blow cold- Doesn't need a charge
We have a 1986 Terry Taurus triler with an a/c unit that only says "Coelman TSR" on it. No model number.
The numbers that are on the label for the thermostat switch are:
6701 340
A30 1813 00
P166 24 SA
The knob that controls the heat and the a/c temperature does not appear to be sending an electrical current to the components in the rooftop unit. The fan works on all settings, but we don't get heat or a/c; only ambient air temperature air flow.
A friend tried to give it a freon charge, but that didnt allieviate the problem because the compressor does not appear to be turning on.
The other things listed on the main unit re:
Heater amps 13.2
Fan motor amp 01
Compressor RLA 11.0
Compressor LRA 61.0
Cycle 60 1 phase
MrObvious
  • 115 Answers
SOURCE: air conditioner on pop up camper
yeah, it could be getting low on freon but you also could turn up the ac a bit... if your running at 68 degrees or something turn it up to 72 and it wont freeze up as quick.
Posted on Jun 22, 2009
  • 6 Answers
SOURCE: I have a Coleman model FL 28-R electric fireplace,
There is a fuse located over the heating element in front of the fan. It sits over a small slot above the heating element (probably to cause it to stop working by design). Yes I'm a pessimist. It can be bypassed if it is an emergency by wiring across it. I'm trying to find the replacement fuse now (10amp jet 250v #00575) If you find it please send info to warfalcon23@Gmail.com. I hope we all get our heaters working, for $250 + dollars you'd expect it to last longer than 1 month.
Posted on Dec 28, 2009
  • 1073 Answers
SOURCE: fan in my Central Cooling Conditioner Unit are not running
NEVER POKE AT ANY PRODUCT on a heating and cooling system it need to be serviced by a trained tech that knows what is going on in the unit, poking around can cause death and at the least a large sum of money if you poke the wrong place
Posted on May 20, 2008
22yooper
  • 828 Answers
SOURCE: PROBLEM WITH DOMETIC RV ROOFTOP AIR conditioner
Check at the compressor terminals between the Red and the terminal for the overload protector to see if you are getting power to the compressor on startup.
Posted on Jul 24, 2008
motor1258
  • 6674 Answers
SOURCE: Compressor trie to start, but don't.
Capacitor is good place to start, once you confirm you have proper voltage getting to the unit.
Posted on Jul 20, 2009
Kenmore HE3
Terry, here's the fault definition and the checks/repairs for it... F/06; Drive Motor Tachometer Error "The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes." Check/Repair; * Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) * Check the Drive Motor * Check the MCU * Check the Wire Harness If you can next time, please provide the entire model number in your post so we can help a bit more. Kenmore doesn't actually manufacture anything, they purchase their units from manufacturers and slap the Kenmore label on them. The model number is located just inside the door on the frame of the unit.
Oct 03, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Fabrique nationale bolt action rifle serial number TS20330 what year was it made
Which model?
Ballista, Karabiner 98k, Model 1924 / Model 1930, Model 1950, Model 30-11, PBR, SPR, or TSR?
Feb 15, 2014 | Optics
I have a Homelite-terry TEXTRON chain saw does it take a gas oil mixture?
I have a Homelite Terry Textron X76 T83-03010 Unit 50150.
how do you change the fuel line?
Sep 02, 2012 | Garden
Tascam TSR-8
It might be availble but if you have the old one it is more cost effective to have new rubber put on the present one as sent to Terry Witt in Michigan who has done many rollers for me in my professional service business. I have had him do rollers for TSR8, 38, 42B and many other units. It cost about $35.
Go to the web and type in Terry's rubber rollers. There is a Pdf form to fill out and then just send in the roller- about a week later you get back a perfectly new one.
Jun 08, 2012 | Audio Players & Recorders
Where do I find the serial number for a Rheem Stellar gas storage hot water unit
Serial number should be on label on side of tank.
Labels contain information like model number, tank capacity and BTUs
First 4 digits of serial number are date of manufacture: for example 0604 is June 2004
Take photo of label for easy reading and for your records
http://www.rheem.com/products/tank_water_heaters/gas_water_heaters/
Label for Craftmaster Gas 30 gallon:
Dec 15, 2010 | Rheem Water Heaters
I have a 1986 RV with the orginal Rooftop AC made
Some can is correct generally not worth the effort
New they are around $ 500 and you won't worry about leaks
Jun 03, 2009 | Dometic Rooftop RV Air Conditioner
95 taurus stalls out when temperature exceeds 102. The temperature gage seems to be in the normal range , when this occurs. Once car has cooled off, it drives fine. I have read that the 95 Taurus has had...
your evaprative emissions could be purging into the engine at that point too, giving too rich a mixture.
here's what you are referring to:
ISSUE: A reduced power, hesitation, stalling at low vehicle speed, idling and/or a no start condition may occur on some vehicles in hot ambient temperatures and/or high altitudes. In addition, a no start may result while the engine is still hot and the vehicle has been parked for a short period. A stall may also occur when moving the vehicle from idle. This may be caused by a lack of vapor ports in the fuel pump, resulting in a vapor lock condition or internal high wear of the fuel pump components due to tank contaminants.
ACTION: Perform normal diagnostic routines as described in the appropriate year Powertrain Control/Emissions Diagnosis Manual (PC/ED). If the condition still exists after all diagnostics are followed, replace the fuel pump with a new turbine fuel pump. Refer to the following Part Application Chart for correct part usage. Also, replace in-line fuel filter with a new filter (E7DZ-9155-A). The new turbine fuel pump will reduce the possibility of vapor lock in high ambient temperatures. Refer to the appropriate model/year Service Manual for removal and installation procedures.
PART APPLICATION CHART Model Year Vehicle Application Part Number 1986-95 Taurus/Sable 16 gal. tank - analog cluster F4DZ-9H307-A 1986-95 Taurus/Sable 18.6 gal. tank - analog cluster F4DZ-9H307-B 1988-94 Continental 18.6 gal. tank - electronic cluster F4DZ-9H307-B 1986-89 Taurus/Sable 18.6 gal. tank - electronic cluster F4DZ-9H307-A 1990-95 Taurus/Sable 18.6 gal. tank - electronic cluster F4DZ-9H307-C
PART NUMBER PART NAME F4DZ-9H307-A Fuel Pump And Sender Assembly F4DZ-9H307-B Fuel Pump And Sender Assembly F4DZ-9H307-C Fuel Pump And Sender Assembly F4PZ-9H307-A Fuel Pump And Sender Assembly E7DZ-9155-A Fuel Filter
Apr 22, 2009 | 1995 Ford Taurus
Gives numbers instead of names on main rds and highways
The Garmins are designed to read the highway or interstate numbers instead of names. This is because on the markers on the side of the road, they are labeled by numbers. Here in NY it calls the Long Island Expressway I-495, the Clearview I-295, etc. If the unit is speaking the names of surface streets, it is working as it was built to.
Oct 26, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Sport & Outdoor - Others Logo
1,252 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
